More NCPA help
BanditBBS
More NCPA help
Post by BanditBBS »
testing NCPA more here.
1.)I grabbed check_ncpa.py and attempted to do this:
[clarkj@rn000002 libexec]$ ./check_ncpa.py -H wdcae-pinf05p -t thisisatest -M cpu --list
Usage: check_ncpa.py [options]
check_ncpa.py: error: no such option: --list
yet, in the documents it shows:
./check_ncpa.py -H ncpaserver -t brody -M cpu --list
Will return a tree representing all of the values you can monitor via NCPA under the cpu tree. To look at everything you could possibly monitor, simply omit the -M flag and its argument.
2.) My end goal here in this testing phase it to passively send drive checks back to nagios. Hopefully with different thresholds possible per drive and also automatically picking up new drives added to systems
3.) in the API, physical is miss-spelled phyical.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: More NCPA help
What is the version of NCPA that you are using? It seems this works for me...
[root@testbox libexec]# ./check_ncpa.py -H x.x.x.x -t mytoken -M cpu --list
cpu :
    count : 8
    idle : [[1019830.25, 1075268.375, 978552.9375, 1089140.75, 1011767.0625, 1082121.0, 984572.625, 1077651.5], u'ms']
    percent : lazy
    system : [[61082.5, 17942.75, 90000.9375, 7501.875, 56677.9375, 11611.625, 62382.0625, 13858.75], u'ms']
    user : [[18543.58984375, 6244.8916015625, 30901.89453125, 2813.025634765625, 31010.61328125, 5722.81884765625, 52500.6875, 7944.97509765625], u'ms']
Do you have any errors in the "ncpa_listener.log"?
Nice catch on the "phyical"! :) We will need to fix this...
BanditBBS
Re: More NCPA help
Post by BanditBBS »
NCPA is 1.4 and check_ncpa.py I grabbed from the exchange which is 1.0.
Re: More NCPA help
Can you see the metrics in the web interface?
https://<ip address>:5693/api/cpu
BanditBBS
Re: More NCPA help
Post by BanditBBS »
No errors
yes I can see the full api
The problem seems to be with check_ncpa.py as it says list isn't a valid option.
BanditBBS
Re: More NCPA help
Post by BanditBBS »
I d/l this version http://exchange.nagios.org/directory/Pl ... pa/details which seems to be rather old now that I looked at the code.
This version https://github.com/NagiosEnterprises/nc ... ck_ncpa.py seems much newer and has the list option.
Why is the exchange not updated and why is the version on exchange labeled 1.0 and the github one labeled 0.1 yet the github is better.
Which should I be using, the github or even a different version?
Re: More NCPA help
Just talked to Nick. The GitHub's version is newer. I updated the links. Let us know if the GitHub's version works for you.
BanditBBS
Re: More NCPA help
Post by BanditBBS »
lmiltchev wrote:Just talked to Nick. The GitHub's version is newer. I updated the links. Let us know if the GitHub's version works for you.
What are the requirements for running the latest version, I get this when running it:
Traceback (most recent call last):
  File "./check_ncpa.py", line 13, in <module>
    import urllib.request, urllib.parse, urllib.error
ImportError: No module named request
sreinhardt
-fno-stack-protector
Re: More NCPA help
Post by sreinhardt »
check_ncpa is intended to be entirely self contained, provided python 3 on linux systems, with the notable exception of python-dateutil. Do you know if your default python installation is set to 2 or 3? You might also try it like:
python3 check_ncpa.py -H wdcae-pinf05p -t thisisatest -M cpu --list
BanditBBS
Re: More NCPA help
Post by BanditBBS »
There's my issue, python2 is installed, not 3. Now I have to think long and hard if upgrading will break the few python scripts I have....hmmm
