When running the backup script, I occasionally get the message in the subject line. Are there any ramifications or is that simply informational?
Thanks a million.
file changed as we read it
Re: file changed as we read it
Can you provide an example of what you are talking about? Which subject line, and what does the message say?
Sure. Just ran it again and here's the output. It doesn't always do this. In fact, I have been running it until I didn't get it then sacking that tarball away. Appreciate it.
[root@nagios scripts]# ./backup_xi.sh
Backing up Core Config Manager (NagiosQL)...
tar: Removing leading `/' from member names
Backing up Nagios Core...
tar: /usr/local/nagios/share/perfdata/Procurve-WE-Office-5406: file changed as we read it
tar: /usr/local/nagios/share/perfdata/Procurve-DH-A-Building-MacLab: file changed as we read it
tar: /usr/local/nagios/share/perfdata/Procurve-DO-Building-C: file changed as we read it
tar: /usr/local/nagios/var/ndo.sock: socket ignored
Backing up Nagios XI...
Backing up MRTG...
Backing up MySQL databases...
Backing up PostgresQL databases...
Backing up logrotate config files...
Backing up Apache config files...
Compressing backup...
BACKUP COMPLETE
Backup stored in /store/backups/nagiosxi/1394817029.tar.gz
Backing up MRTG...
BACKUP COMPLETE
It should not cause any issues, but you may lose a few checks in the backup if the rrds are updated during the backup. Nothing to worry about. You could always stop npcd, run teh backup, and then restart npcd, but I don't think it is necessary.
