plugin not found?
plugin not found?
Hi I have imported a plugin to monitor HP blade temperature "check_HPBladeSystemTemperature.php" successfully. However I cannot find it in both host and service list. How should I use this plugin, (and all other ones in the correct way)? Thank you.
sreinhardt
- -fno-stack-protector
Re: plugin not found?
Just like in core, before you can use a plugin with a host or service, you must create a command definition that instructs nagios how to use the new plugin. This can be done at Configure-->Core Config Manager -> Commands
