nagios is telling me: CRITICAL - Socket timeout after 10 seconds
but when i do a manual check_ftp command, i get this: FTP OK - 0.010 second response time on port 21
the load average on the target server is not high at all in relation to how it normally runs.
any ideas?
i am stumped on CRITICAL FTP socket timeout
Re: i am stumped on CRITICAL FTP socket timeout
Can we see the service and command definition for this check?
services.cfg:
commands.cfg
host_name servername.serverdomain
service_description FTP
initial_state o
is_volatile 0
max_check_attempts 7
normal_check_interval 2
retry_interval 1
first_notification_delay 0
active_checks_enabled 1
passive_checks_enabled 1
check_period 24x7
parallelize_check 1
obsess_over_service 1
check_freshness 1
freshness_threshold 180
event_handler_enabled 1
process_perf_data 1
retain_status_information 1
notification_interval 4
notification_period 24x7
notifications_enabled 1
action_url /pnp4nagios/index.php?host=$HOSTNAME$&srv=$SERVICEDESC$
check_command check_nrpe!check_ftp
display_name FTP
notification_options w,u,c,r,f,s
stalking_options o,w,u,c
contact_groups Null Placeholder Group
servicegroups Internal Services
commands.cfg
command_name check_ftp
command_line $USER1$/check_ftp -H $HOSTADDRESS$ $ARG1$ -t 30
Well the reason it is not working is because you have it set to use check_nrpe, not check_ftp. Also, did you put "servername.serverdomain" on purpose to hide the real host address, or is that what you actually have in your config?
it was working just fine for months with that configuration set that way, and it's working with all the other web servers we are monitoring FTP with that configuration.tmcdonald wrote:Well the reason it is not working is because you have it set to use check_nrpe, not check_ftp. Also, did you put "servername.serverdomain" on purpose to hide the real host address, or is that what you actually have in your config?
and, you are correct, servername.serverdomain is something i substituted for the real server/domain names.
It may have been working fine, but I think you misunderstand how NRPE fits in.
NRPE is used to execute commands on a remote server. When you have "check_nrpe!check_ftp" defined as the check command, it means you want the remote server to run check_ftp as opposed to Nagios running it, and then have the remote server send the results of the check back to Nagios. But from what you are saying, running check_ftp from the Nagios command line works (and this would make sense). However that is not the same as having NRPE run the same command on the remote server. Running check_ftp on the command line would be equivalent to having "check_ftp" as the check command on the service.
Do you really mean to use NRPE to run this check?
oh thank you so much for clarifying and explaining that. it makes perfect sense why the check_ftp command works but the nrpe check would send an alert.
as for do i really want nrpe to do the checks? i'm not sure ... all this was put in place before i started working here so i'll have to check with the team lead to get his input.
thank you again for your help ... it was very beneficial.
No problem. Let us know what you come up with. At my old job I inherited a Nagios installation so I know how confusing it can be at times!
