Nagios Core 4.0.4 init script
Nagios Core version: 4.0.4
OS: CentOS 6.5 (64-bit)
Looking at the changelog for version 4.0.4, I see that the init script was re-written. Previous to this version, I was able to start/stop/restart Nagios without any problem, but now it seems that it is required to have the Nagios user have a login shell (/bin/bash vs. /sbin/nologin). I have always had my daemon user's login shell disabled, as is good security practice.
I'm wondering why the init script now requires a login shell when it never did before? Is there a way to modify the init script so it doesn't?
Thanks!
Thanks!
Re: Nagios Core 4.0.4 init script
What command are you using to restart/start/stop Nagios? We've had some people report problems using /etc/init.d/ scripts so any additional info you can give us would help in identifying the issue.
As for the requirement of a shell, I will have to talk to the developers for an official answer.
I have used "service nagios start" and "/etc/init.d/nagios start", which are basically the same thing as far as I know. I have also restarted the server, and Nagios is set to start on system startup (using the chkconfig utility). All of these methods give the error "This account is currently not available." and Nagios fails to start. In the past, this error always showed up, but Nagios always started. I'm pretty sure this error was because I had the login shell set to "/sbin/nologin".When I now set the shell to "/bin/bash", the error doesn't appear and Nagios starts correctly.
If it's not too much trouble, an official answer would be nice. I'm not really comfortable with having a daemon user have a login shell, and I suspect most others wouldn't want this either. If I need to submit a bug report or feature request to get this fixed in the next version, I'd be willing to do that.
Thanks!
Thanks!
Would it be possible to post your current /etc/init.d/nagios ?
Sure, here it is:
#!/bin/sh
# chkconfig: 345 99 01
# description: Nagios network monitor
# processname: nagios
# File : nagios
# Author : Jorge Sanchez Aymar ([email protected])
# Changelog :
# 1999-07-09 Karl DeBisschop <[email protected]>
# - setup for autoconf
# - add reload function
# 1999-08-06 Ethan Galstad <[email protected]>
# - Added configuration info for use with RedHat's chkconfig tool
# per Fran Boon's suggestion
# 1999-08-13 Jim Popovitch <[email protected]>
# - added variable for nagios/var directory
# - cd into nagios/var directory before creating tmp files on startup
# 1999-08-16 Ethan Galstad <[email protected]>
# - Added test for rc.d directory as suggested by Karl DeBisschop
# 2000-07-23 Karl DeBisschop <[email protected]>
# - Clean out redhat macros and other dependencies
# 2003-01-11 Ethan Galstad <[email protected]>
# - Updated su syntax (Gary Miller)
# Description: Starts and stops the Nagios monitor
# used to provide network services status.
### BEGIN INIT INFO
# Provides: nagios
# Required-Start: $local_fs $syslog $network
# Required-Stop: $local_fs $syslog $network
# Short-Description: Starts and stops the Nagios monitoring server
# Description: Starts and stops the Nagios monitoring server
### END INIT INFO
# Load any extra environment variables for Nagios and its plugins
if test -f /etc/sysconfig/nagios; then
. /etc/sysconfig/nagios
fi
# Source function library
# Some *nix do not have an rc.d directory, so do a test first
if [ -f /etc/rc.d/init.d/functions ]; then
. /etc/rc.d/init.d/functions
elif [ -f /etc/init.d/functions ]; then
. /etc/init.d/functions
elif [ -f /lib/lsb/init-functions ]; then
. /lib/lsb/init-functions
fi
prefix=/opt/nagios
exec_prefix=${prefix}
NagiosBin=${exec_prefix}/bin/nagios
NagiosCfgFile=${prefix}/etc/nagios.cfg
NagiosStatusFile=${prefix}/var/status.dat
NagiosRetentionFile=${prefix}/var/retention.dat
NagiosCommandFile=${prefix}/var/rw/nagios.cmd
NagiosVarDir=${prefix}/var
NagiosRunFile=${prefix}/var/nagios.lock
NagiosLockDir=/var/lock/subsys
NagiosLockFile=nagios
NagiosCGIDir=${exec_prefix}/sbin
NagiosUser=nagios
NagiosGroup=nagios
checkconfig="true"
# Automate addition of RAMDISK based on environment variables
USE_RAMDISK=${USE_RAMDISK:-0}
if test "$USE_RAMDISK" -ne 0 && test "$RAMDISK_SIZE"X != "X"; then
ramdisk=`mount |grep "$ramdiskdir type tmpfs"`
if [ "$ramdisk"X == "X" ]; then
mkdir -p -m 0755 ${RAMDISK_DIR}
mount -t tmpfs -o size=${RAMDISK_SIZE}m tmpfs ${RAMDISK_DIR}
mkdir -p -m 0755 ${RAMDISK_DIR}/checkresults
chown -R $NagiosUser:$NagiosGroup ${RAMDISK_DIR}
fi
fi
check_config() {
TMPFILE=$(mktemp /tmp/.configtest.XXXXXXXX)
su - $NagiosUser -c "$NagiosBin -vp $NagiosCfgFile" > "$TMPFILE"
WARN=`grep ^"Total Warnings:" "$TMPFILE" |awk -F: '{print \$2}' |sed s/' '//g`
ERR=`grep ^"Total Errors:" "$TMPFILE" |awk -F: '{print \$2}' |sed s/' '//g`
if test "$WARN" = "0" && test "${ERR}" = "0"; then
echo "OK - Configuration check verified" > /var/run/nagios.configtest
chmod 0644 /var/run/nagios.configtest
/bin/rm "$TMPFILE"
return 0
elif test "${ERR}" = "0"; then
# We'll write out the errors to a file we can have a
# script watching for
echo "WARNING: Warnings in config files - see log for details: /var/run/nagios.configtest" > /var/run/nagios.configtest
egrep -i "(^warning|^error)" "$TMPFILE" >> /var/run/nagios.configtest
/bin/rm "$TMPFILE"
return 0
else
echo "ERROR: Errors in config files - see log for details: /var/run/nagios.configtest" > /var/run/nagios.configtest
cat "$TMPFILE"
exit 8
fi
status_nagios ()
if test -x $NagiosCGI/daemonchk.cgi; then
if $NagiosCGI/daemonchk.cgi -l $NagiosRunFile; then
return 0
else
return 1
fi
else
if ps -p $NagiosPID > /dev/null 2>&1; then
return 0
else
return 1
fi
fi
return 1
printstatus_nagios()
if status_nagios $1 $2; then
echo "nagios (pid $NagiosPID) is running..."
else
echo "nagios is not running"
fi
killproc_nagios ()
kill $2 $NagiosPID
pid_nagios ()
if test ! -f $NagiosRunFile; then
echo "No lock file found in $NagiosRunFile"
exit 1
fi
NagiosPID=`head -n 1 $NagiosRunFile`
# Check that nagios exists.
if [ ! -f $NagiosBin ]; then
echo "Executable file $NagiosBin not found. Exiting."
exit 1
fi
# Check that nagios.cfg exists.
if [ ! -f $NagiosCfgFile ]; then
echo "Configuration file $NagiosCfgFile not found. Exiting."
exit 1
fi
# See how we were called.
case "$1" in
start)
echo -n "Starting nagios:"
if test "$checkconfig" = "true"; then
check_config
fi
if [ $? -eq 0 ]; then
su - $NagiosUser -c "touch $NagiosVarDir/nagios.log $NagiosRetentionFile"
rm -f $NagiosCommandFile
touch $NagiosRunFile
chown $NagiosUser:$NagiosGroup $NagiosRunFile
$NagiosBin -d $NagiosCfgFile
if [ -d $NagiosLockDir ]; then touch $NagiosLockDir/$NagiosLockFile; fi
echo " done."
exit 0
else
echo "CONFIG ERROR! Start aborted. Check your Nagios configuration."
exit 1
fi
stop)
echo -n "Stopping nagios: "
pid_nagios
killproc_nagios nagios
# now we have to wait for nagios to exit and remove its
# own NagiosRunFile, otherwise a following "start" could
# happen, and then the exiting nagios will remove the
# new NagiosRunFile, allowing multiple nagios daemons
# to (sooner or later) run - John Sellens
#echo -n 'Waiting for nagios to exit .'
for i in 1 2 3 4 5 6 7 8 9 10 ; do
if status_nagios > /dev/null; then
echo -n '.'
sleep 1
else
break
fi
done
echo ''
echo 'Warning - nagios did not exit in a timely manner'
else
echo 'done.'
fi
rm -f $NagiosStatusFile $NagiosRunFile $NagiosLockDir/$NagiosLockFile $NagiosCommandFile
status)
pid_nagios
printstatus_nagios nagios
checkconfig)
printf "Running configuration check..."
check_config
fi
echo " OK."
else
echo " CONFIG ERROR! Check your Nagios configuration."
exit 1
fi
restart)
check_config
fi
$0 stop
$0 start
reload|force-reload)
check_config
fi
$0 start
else
pid_nagios
printf "Reloading nagios configuration..."
killproc_nagios nagios -HUP
echo "done"
else
$0 stop
$0 start
fi
fi
configtest)
echo "Usage: nagios {start|stop|restart|reload|force-reload|status|checkconfig|configtest}"
exit 1
esac
# End of this script
I believe I have found the problem, and tested it with a setup like yours. You should be able to use the following in your /etc/init.d/nagios
Just 2 lines were changed, 84 & 186
#!/bin/sh
# File : nagios
# Changelog :
### BEGIN INIT INFO
# Provides: nagios
### END INIT INFO
fi
fi
prefix=/opt/nagios
NagiosUser=nagios
NagiosGroup=nagios
checkconfig="true"
fi
fi
check_config() {
$NagiosBin -vp $NagiosCfgFile > "$TMPFILE"
/bin/rm "$TMPFILE"
return 0
/bin/rm "$TMPFILE"
return 0
else
cat "$TMPFILE"
exit 8
fi
status_nagios ()
return 0
else
return 1
fi
else
return 0
else
return 1
fi
fi
return 1
else
fi
killproc_nagios ()
kill $2 $NagiosPID
pid_nagios ()
exit 1
fi
exit 1
fi
exit 1
fi
case "$1" in
start)
check_config
fi
echo " done."
exit 0
else
exit 1
fi
stop)
pid_nagios
echo -n '.'
sleep 1
else
break
fi
done
echo ''
else
echo 'done.'
fi
status)
pid_nagios
checkconfig)
check_config
fi
echo " OK."
else
exit 1
fi
restart)
check_config
fi
$0 stop
$0 start
check_config
fi
$0 start
else
pid_nagios
echo "done"
else
$0 stop
$0 start
fi
fi
configtest)
exit 1
esac
# End of this scriptRe: Nagios Core 4.0.4 init script
Thank you so much for your quick replies and all your help. It works perfectly now!
Should I submit a bug report for this?
I believe Scott actually made the changes already, and is working on pushing them to the current, downloadable source.
I ran into this too - tested the fixes above (+1 more listed below) and it appears to correct the init script in the 4.0.4 tar.gz
One more entry, about 10 lines from the bottom:
change to
configtest)
configtest)
Thanks millisa, I changed the line you suggested as well and now the config test function works.
Thank you all again for your help.
