Check for a pattern is NOT found issue alarm
apollopt
Post by apollopt »
Hello All,
I have tried to Google for some hours now but without luck...
I'm trying to find a NAGIOS check that do more or less the opposite then the check_logs check.
I want a check that checks a log file and if he don't find a predefined pattern he issues an alarm...
For example i would like to to check on a file for the patter "[SOME-END], [SOME-BEGIN]" and if this pattern is not find a alarm is issue...
Thanks in advance.
abrist
Red Shirt
Re: Check for a pattern is NOT found issue alarm
Post by abrist »
Have you considered using the negate plugin? You can use the negate plugin to change one type of state to another, i.e. Critical to Ok and Ok to Critical.
http://assets.nagios.com/downloads/nagi ... Plugin.pdf
