Service shows in listing, but not in configuration
ChathamDaleJ
I have a problem with two hosts with the same service. The service shows up when I list services for the host, but it does not appear on the configuration page, nor can i grep through /usr/local/nagios/etc/services/* to locate the service. How do I delete this thing? If I delete all shown services and the host, it won't pass the preflight because this service is orphaned.
Any ideas?
Any ideas?
Re: Service shows in listing, but not in configuration
You're saying it doesn't show up in the CCM at all? Have you tried searching for both the service name and, separately, the host it is attached to? Sometimes a service has a name matching its host and it can get confusing.
ChathamDaleJ
I have gone to /usr/local/nagios/etc
From there I executed the command:
grep <hostname> */*
grep <service> */*
The host/service combination does not exist. The IP does not exist under an improper host name.
I have two service that are acting like this.
I have not dumped the MySQL yet, but it's my next step. I'll jump right on that one in my copious spare time
grep <hostname> */*
grep <service> */*
You may have a "ghost" host/service. If you are sure you deleted them in the CCM, take a look at what you have in the hosts/services directories (sort by time modified):
Look at the timestamps. If you have a ghost host/service, the config wouldn't be updated. If you find the file, you can manually delete it in the CLI.
Note: To rule out multiple nagios instances running, run the following commands:
ll -t /usr/local/nagios/etc/hosts
ll -t /usr/local/nagios/etc/servicesNote: To rule out multiple nagios instances running, run the following commands:
service nagios stop
killall nagios
service nagios startBe sure to check out our Knowledgebase for helpful articles and solutions!
ChathamDaleJ
The host with the ghost service is gbnagios01
The ghost service is lwsmd
I executed the command locate gbnagios01.cfg
[root@gbnagios01 hosts]# locate gbnagios01.cfg
/etc/nagiosql/backup/hosts/gbnagios01.cfg_old_20140319141534
/etc/nagiosql/backup/hosts/gbnagios01.cfg_old_20140319141957
/etc/nagiosql/backup/hosts/gbnagios01.cfg_old_20140319142447
/etc/nagiosql/backup/hosts/gbnagios01.cfg_old_20140319145528
/etc/nagiosql/backup/services/gbnagios01.cfg_old_20140319141559
/etc/nagiosql/backup/services/gbnagios01.cfg_old_20140319142017
/etc/nagiosql/backup/services/gbnagios01.cfg_old_20140319142508
/etc/nagiosql/backup/services/gbnagios01.cfg_old_20140319145551
/store/backups/nagiosxi/1389198430/usr/local/nagios/etc/hosts/gbnagios01.cfg
/store/backups/nagiosxi/1389198430/usr/local/nagios/etc/services/gbnagios01.cfg
/store/backups/nagiosxi/1389198430/usr/local/nagios/etc/services.20131030/gbnagios01.cfg
Then, I ran:
[root@gbnagios01 services]# locate gbnagios01.cfg | \
> while read file
> do
> grep -i lwsmd $file
> done
You have new mail in /var/spool/mail/root
No hits.
Then, I ran:
> while read file
> do
> grep -i lwsmd $file
> done
No hits.
Actually, I would run the following if the service name is lwsmd
This will find the potential files the config could be in.
Remember, it could be because you have a host_group added to a service which would add the service to multiple hosts, so it is possible that the host_name is not in the config...
grep -R lwsmd /usr/local/nagios/etcThis will find the potential files the config could be in.
ChathamDaleJ
Ran grep -R, no surprises. The only place that lwsmd shows in in /usr/local/nagios/etc/services
No services defiend in hostgroups
What is the output of the following command?
grep -R lwsmd /usr/local/nagios/etc/servicesBe sure to check out our Knowledgebase for helpful articles and solutions!
ChathamDaleJ
OK, that one was a bit obvious and I've run it many times looking for this.
Of particular interest:
[root@gbnagios01 nagios]# cd /usr/local/nagios
[root@gbnagios01 nagios]# grep -R lwsmd etc/services |grep nagios
But here is the whole list.
Moderator Note: Please use code tags when posting long output. I have edited your post for reference. -- tmcdonald
/usr/local/nagios/etc/services/gba2r5lb01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/vm-ac123536.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr4lb09.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/vm-ac123535.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr5cp03.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplcpq01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbgenius06.cfg: service_description lwsmd
/usr/local/nagios/etc/services/gbgenius06.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'!!!!!!!
/usr/local/nagios/etc/services/gbplr4lb11.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/vm-ac12352f.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/vm-ac123523.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplebuild03.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplmoc01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr4lb01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbgenius-sh02.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplc20-03.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbrh4pt01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbgenius01.cfg: service_description lwsmd
/usr/local/nagios/etc/services/gbgenius01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'!!!!!!!
/usr/local/nagios/etc/services/gbflex01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbattconnect.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbgenius03.cfg: service_description lwsmd
/usr/local/nagios/etc/services/gbgenius03.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'!!!!!!!
/usr/local/nagios/etc/services/gbplwambld01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbrancid.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gba2saas03.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr5cnct.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/vm-ac123519.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'!!!!!!!
/usr/local/nagios/etc/services/vm-ac123524.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbjira01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplcfe01.cfg: service_description lwsmd
/usr/local/nagios/etc/services/gbplcfe01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'!!!!!!!
/usr/local/nagios/etc/services/gbtoolbox1.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/vm-ac123525.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplc20-04.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr4lb03.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplesbc02.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gba2saas01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplefusn.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/snafu.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/vm-ac123522.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'!!!!!!!
/usr/local/nagios/etc/services/iwebwww.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr4lb12.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr4lb07.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr4cp01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbhomertst.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr5vc02.cfg: service_description lwsmd
/usr/local/nagios/etc/services/gbplr5vc02.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'!!!!!!!
/usr/local/nagios/etc/services/gbplcpq02.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplbrstg01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbgenius101.cfg: service_description lwsmd
/usr/local/nagios/etc/services/gbgenius101.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'!!!!!!!
/usr/local/nagios/etc/services/gbplr4lb06.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr4lb05.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbgenius98.cfg: service_description lwsmd
/usr/local/nagios/etc/services/gbgenius98.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'!!!!!!!
/usr/local/nagios/etc/services/gbmwest-test.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplesbc03.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbpltech04.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr4s301.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplc20-01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbiweblx01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/vm-ac12352d.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/vm-ac123530.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbjiraprod01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr5ccc01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/g6g2cvs.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbpltech03.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbwamdsgn04.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplebuild04.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gba2cfg01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbgengit01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbgenius02.cfg: service_description lwsmd
/usr/local/nagios/etc/services/gbgenius02.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -t 60 -n 'lwsmd' -w '0' -c '0'!!!!!!!
/usr/local/nagios/etc/services/gbgenius99.cfg: service_description lwsmd
/usr/local/nagios/etc/services/gbgenius99.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'!!!!!!!
/usr/local/nagios/etc/services/gbcvpls01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbwamdsgn01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbsuse1001.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr4vc02.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbwamdsgn02.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/wrtpy0ur.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr4cp04.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/vm-ac12352e.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbgenius08.cfg: service_description lwsmd
/usr/local/nagios/etc/services/gbgenius08.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'!!!!!!!
/usr/local/nagios/etc/services/gbwebalarm.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr5cp02.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr5hw03.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbgenius04.cfg: service_description lwsmd
/usr/local/nagios/etc/services/gbgenius04.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'!!!!!!!
/usr/local/nagios/etc/services/gbplr4lb04.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbgenius-sh01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplgts.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr4lb08.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbpca03.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gba2r4lb01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr4lb10.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbgenius07.cfg: service_description lwsmd
/usr/local/nagios/etc/services/gbgenius07.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'!!!!!!!
/usr/local/nagios/etc/services/gbplr4cp03.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr4lb02.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbitjump01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbgenius05.cfg: service_description lwsmd
/usr/local/nagios/etc/services/gbgenius05.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'!!!!!!!
/usr/local/nagios/etc/services/gbengdata01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplc20-02.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplgvm01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplesbc01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr4lbcc.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbpltech02.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplr4cp02.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbcvtools01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbgac01.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbwamdsgn03.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
/usr/local/nagios/etc/services/gbplcas.cfg: check_command check_xi_service_snmp_linux_process! -C gb2k --v2c -n 'lwsmd' -w '0' -c '0'
sreinhardt
- -fno-stack-protector
Instead of having you continue to grep for various strings and such within your configs, could you PM one of us your latest configuration snapshot or profile.zip please? I think it would be far faster for us to look at it ourselves and dig through it.
