HI ,
I have installed with Nagios NSCA Server and Nagios NSCA client.
I see Nagios client is sending the traps to Nagios Server (/var/log/messages) but this alert is not populated in nagios.log.
Can some please help me on this
pavan
Do not double post, open a new thread like you did here instead of a post on someone elses thread that is not relevant.
Nagios NSCA
Nagios NSCA
Reason: Do not double post, open a new thread like you did here instead of a post on someone elses thread that is not relevant.
Re: Nagios NSCA
Have you created objects for your passive incoming check results as described here?:
http://nagios.sourceforge.net/download/ ... _Setup.pdf
What are you seeing in the logs, can you copy a couple snippets?
Also, what version of NSCA are you running on the remote host, and Core?
