I have something similar to this post:
http://support.nagios.com/forum/viewtop ... =16&t=9041
When in fusion, I get session timeouts as well. It´s back up when I logon to the XiServer.
Not sure if the permalink fixes the tiemouts (I use 2012R2.5)
If it does, I wonder if I could get a permalink for just the operations screen popout.
I have operations screen popups in a rotating scheme view for a number of Xi servers.
These need to be displayed on an overhead display. There´s no need to interact with this display.
Just visually check the message, and use their own useraccounts-desktops from there on.
fusion view timeouts
Re: fusion view timeouts
Make sure the hostname that fusion uses is the same as the hostname in the perma-link.
e.g. If fusion uses
http://scott.nagios.local/nagiosxi/
and you add a permalink of
http://192.168.5.182/nagiosxi/dashboards/?&xiwindow=http%3A%2F%2F192.168.5.182%2Fnagiosxi%2Fdashboards%2Fdashboard.php%3Fid%3Dtd3ufmpk
These would be 2 different hosts and will use 2 different cookies....
e.g. If fusion uses
