monitoring linux with snmp
srikanth.kallu
Post by srikanth.kallu »
I am trying to monitor Linux with SNMP
I added this line in snmpd.conf
rocummunity public 192.168.0.0/244
on the server i get this error
[root@nagiosxi libexec]# ./check_snmp_storage.pl -H 192.168.0.132 -C public -m "^/$" -w 2 -c 4
ERROR: Description/Type table : Requested table is empty or does not exist.
Can i please get help
Edit: Please dont assume i am reposting this, I still need help for this.
Reason: Merged your two posts, please do not double post as that will bump you lower on our "to be replied to" list. Warning 2.
Re: monitoring linux with snmp
I assume you meant:
not
Try adding localhost:
rocummunity public localhost
Restart snmpd:
service snmpd restart
and test it again:
srikanth.kallu
I have changed it on snmpd.conf and restarted the service i still have the same error.
192.168.0.132 is the IP of the server i am trying to monitor
10.0.12.45 is the IP of my Nagios server.
sreinhardt
-fno-stack-protector
Post by sreinhardt »
The issue is not with what host is allowed, as that seems correct, but instead with what tables you have given that community string access to. I need to check some documentation, and will edit this post to reflect what you need to look for if you do not post back first.
Actually, in terms of making this easiest, could you post the entire snmpd.conf and I will take a look at it please.
srikanth.kallu
I have attached snmpd.conf
Reason: Merged your two posts, please do not double post as that will bump you lower on our "to be replied to" list. Warning 2...
sreinhardt
Try adding the following lines to the end of your config and restarting snmpd.
group   rocummunitygroup any           rocummunity
view    roview    included   .1
access  rocummunitygroup ""      any       noauth    exact  roview none none
srikanth.kallu
I still haver the same error
srikanth.kallu
I made few changes in the snmpd.conf and it ssems to be working from nagios server, but still cannot make it work from GUI/Wizard.
[root@nagiosxi libexec]# ./check_snmp_storage.pl -H 192.168.0.132 -C mouser -m "^/$" -w 2 -c 4
/: 38%used(18921MB/50397MB) (>4%) : CRITICAL
I am attaching my new snmpd.conf file
Can you show us the service definition? Does it look something like this?
	host_name			192.168.0.132
	service_description		/ Disk Usage
	use				xiwizard_linuxsnmp_storage
	check_command			check_xi_service_snmp_linux_storage! -C mouser --v2c -m "^/$" -w 80 -c 95 -f
	max_check_attempts		5
	check_interval			5
	retry_interval			1
	check_period			xi_timeperiod_24x7
	notification_interval		60
	notification_period		xi_timeperiod_24x7
	contacts			nagiosadmin
	_xiwizard			linuxsnmp
	register			1
srikanth.kallu
Where can i find this file
