Use 'Mobile Phone Number' in custom commands
uglystory
Post by uglystory »
Nagios XI Version 2012R2.9.
CentOS release 6.5 (Final) 2.6.32-358.2.1.el6.x86_64 x86_64.
Gnome is not installed.
Is it possible to use 'Mobile Phone Number' (Configure->My Account Settings->Notifications Methods->Mobile Text) in custom commands?
If it is, what macro or variable name should be used?
Regards,
Tamar
Re: Use 'Mobile Phone Number' in custom commands
Post by slansing »
I'm not quite sure what you mean by this, if you are trying to set up Text notifications, that is the correct page to do so via user notifications. Are you asking if you can some how hook a defined number added via that page to a general Nagios command?
uglystory
Post by uglystory »
Yes, exactly.
Instead of Pager Number in Nagios Core, I would like to use this field with my custom commands.
This is not possible as this is not set as a macro, this field is an XI only feature. You would need to set one of the contact pager macros in the CCM
uglystory
Post by uglystory »
Ok, thanks!
Can we close this thread up?
uglystory
Post by uglystory »
Yes, you can.
I will check developer tools on my own.
Regards,
Tamar
