nagiostats 4.0.4 bug?
jiikoo
Post by jiikoo »
Problem: Some of nagiostats MRTG data variables are not working:
---------- 8< 8< 8< 8< ----------
root@nagios:/home/jiikoo# /usr/local/nagios/bin/nagiostats --mrtg --data=TOTCHKBUF,USEDCMDBUF,HIGHCMDBUF,NAGIOSVERPID
TOTCHKBUF
USEDCMDBUF
HIGHCMDBUF
Nagios 4.0.4 (pid=11497)
prandal
Re: nagiostats 4.0.4 bug?
Post by prandal »
AFAIK, those variables don't exist anymore in Nagios 4.x.
You'll need to remove that one graph out of your mrtg.cfg
nagiostats.c needs amending to remove them from the --help output, too.
jiikoo
Post by jiikoo »
Ok. Thx!
Thanks for the post prandal. I don't see TOTCHKBUF in nagiostats.c in 4.0.4 or 3.5.1
Where were you finding it? Did you mean TOTCMDBUF?
