The new plugin bundle looks great! My only incomapabiltiy issue is with the 'check_dns' plugin. I have the plugin configured in several hundred checks, all expecting just the IP address as the return string. Is it possible to add a parameter to return just the IP address, or allow for sub-string matching?
If the new return string format (IP+A) was due to a specific reason, and can't be changed, let me know and I will start updating
You're present settings are correct, where it should only display the IP. This one must have missed testing, but I am getting to it right way.
