Hi
When we try APPLY CONFIGURATION we are getting following error(attached with this request)
Please guide to solve the issue.
Regards,
Sharath
backend login to the core config manager failed Error
Re: backend login to the core config manager failed Error
Typically when you see this it means you are either missing a required config setting or you have an invalid setting somewhere.
Click "View a snapshot of this configuration error" and you will see all the config snapshots. Click the blue diskette icon for the first entry and you will get a text file to view. Toward the bottom of that text file you will find the errors that are causing the apply to fail.
