Is it possible to use Variables in definition files?
stn021
Post by stn021 »
as described in http://nagios.sourceforge.net/docs/3_0/ ... tvars.html variables can be used in nagios definitions.
I tried that and it doesn't seem to work. The defined variable is interpreted as "0". Here is what I did:
_CHECK_INTERVAL         77
# and:
  host_name                     <my host>
  service_description           <my desc>
  use                           generic-service
  check_command                 <my command>
  check_interval                $_SERVICECHECK_INTERVAL$
If I enter a number instead of $_SERVICECHECK_INTERVAL$ everything is fine, the service works as expected and in the webinterface the correct interval can be checked. With the definition above (and some variations I tried) the service_interval is shown as Zero in the web-interface.
Where did I go wrong ?
THX, stn
abrist
Red Shirt
Re: Is it possible to use Variables in definition files?
Post by abrist »
Custom variable are intended to be passed to plugins/scripts/etc. They are not intended for use as values for config directives and by all accounts, should not work in the method you are attempting.
technick
Post by technick »
You can look at /usr/local/nagios/var/objects.cache and view your custom variable.
Nagios Jedi in training.
stn021
Post by stn021 »
technick wrote:You can look at /usr/local/nagios/var/objects.cache and view your custom variable.
Very cool, thank you. That files list every defined object with all its properties. Allows a quick check of config-changes.
(Side note: In my installation of nagios-core this file is in a different location /var/cache/nagios3/objects.cache)
stn021
Post by stn021 »
abrist wrote:Custom variable are intended to be passed to plugins/scripts/etc. They are not intended for use as values for config directives and by all accounts, should not work in the method you are attempting.
No, they don't, apparently :(
Let me rephrase my question.
I have several identical hosts with identical services. The only differences between the hosts are host_name and address.
So I was wondering
  • Is there a way to duplicate the complete config of a host without having to copy every codeblock (define host{}, define service{}) individually ?
  • or: is it possible to define host{} and services in a single definition so that the whole definition can be replicated in a single short block (or even a single line) with just a different host_name and address ?
  • and: suppose I would like to quickly change a single variable for a host and all its services, for example set check_interval to 1 or 1440 instead of the default 5, and optionally quickly change it back (after testing). What is the quickest way to do that, if possible without rewriting every service ?
THX, stn
technick
Post by technick »
stn021 wrote:
Yes, you can use templates to save yourself A LOT of time. Here is a quick example of how templates save you time.
define host {
       name                                     linux-server
       check_command                            check-host-alive!!!!!!!!
       use                                      generic-host
       max_check_attempts                       4
       check_interval                           1
       retry_interval                           1
       active_checks_enabled                    1
       check_period                             24x7
       contact_groups                           nagios-ops
       notification_interval                    5
       notification_period                      24x7
       notification_options                     d,u,r,
       notifications_enabled                    1
       register                                 0
The above is a template called linux-server. This template is chained to another template called generic-service as well. If you are unaware of how chaining works, please read up on inheritances in Nagios. Now Here are some defined hosts that all use the linux-server template.
define host {
        host_name                       dertcn00
        use                             linux-server
        display_name                    dertcn00
        address                         dertcn00
        register                        1
define host {
        host_name                       dertcn01
        use                             linux-server
        display_name                    dertcn01
        address                         dertcn01
        register                        1
define host {
        host_name                      dertcn02
        use                             linux-server
        display_name                    dertcn02
        address                         dertcn02
        register                        1
Only the bare minimum is being defined with each host and its inheriting the rest of the stuff from the linux-server template.
http://nagios.sourceforge.net/docs/3_0/ ... tance.html
Also you should look into this link, it will save you a lot of time...
http://nagios.sourceforge.net/docs/3_0/ ... ricks.html
abrist
Red Shirt
Post by abrist »
Technick is dead-on once again. Let us know if you have any further questions regarding templates, object inheritance, or custom variables. . .
stn021
Post by stn021 »
technick wrote:
stn021 wrote:
Yes, you can use templates to save yourself A LOT of time. Here is a quick example of ..
Ok, lets See what else is possible...
stn021 wrote:Ok, lets See what else is possible...
Are you asking a question or just stating that you are going to try some things?
stn021
Post by stn021 »
tmcdonald wrote:Are you asking a question or just stating that you are going to try some things?
That was shorthand for "thank you all for the valuable hints and I will now now explore the numerous possibilies to make config files shorter". Sorry, was in a bit of a hurry :)
