VMware Cluster Monitoring
intelXIadmin
Post by intelXIadmin »
Is there a way to monitor all the systems in a cluster through the Vsphere management system, or do we need to monitor each system in the cluster separately.
Regards,
Randy.
Re: VMware Cluster Monitoring
Post by slansing »
The VMware monitoring wizard should be able to check the cluster's status/health:
http://exchange.nagios.org/directory/Ad ... rd/details
And it should be already installed on your Nagios XI server, however, I do not believe it will allow you to check everything that you would be able to if you were monitoring each system in the cluster individually.
