NagiosXI SNMP Trap same IP different Host
mlopez
Post by mlopez »
Hi All,
I'm currently in the process of testing Nagios XI Enterprise to replace a previous monitoring system and wondering if you would be able to answer a couple of questions.
Our environment is only passive snmp traps with over 1,000 hosts and 45 SNMP Trap OID's per.
I have a couple of hosts which have snmp trap servers which redirect the snmp traps from multiple machines and wondering if I could associate same IP, same hostname but a unique indicator depending on Alert information.
Example:
Trap 1:
IP: 10.10.10.10
HOST: Goliath_National_Bank
System Name:BANK_NEWYORK
Description: RDP
Object Value: OFF
Trap 2:
IP: 10.10.10.10
System Name:BANK_CHICAGO
Description: RDP
Object Value: OFF
As you can see in the example I have the same IP and same HOST but the differential indicator is System Name, I want to be able to create 2 hosts with same IP but if System name which comes in the SNMP Trap is different associate to the different host / service accordingly.
Sincerely,
Michael
Re: NagiosXI SNMP Trap same IP different Host
Post by slansing »
This sounds like a good use for trap forwarding in NSTI, a new version is due to be released pretty soon, if you'd like to read up on it:
http://assets.nagios.com/downloads/nagi ... index.html
I believe you have the ability to do what you are talking about with NSTI, though I will have to confirm this with the dev, you may be able to split them by the host header there.
mlopez
Post by mlopez »
Hi slansing,
Thanks again for the reply and you are bang on, I was actually reading about version 2 yesterday night and yes this would do what I am looking for. The biggest thing would be to show all alerts not the most recent one. NTSI2 has a feature which I was reading about that will stick any new alerts unless marked as "READ". I only saw a beta link available in April 16, 2013 http://labs.nagios.com/2013/04/16/nagio ... nsti-v2-0/ but I was reading a post on the nagios forums posted on Thu Jan 30, 2014 10:30 am http://support.nagios.com/forum/viewtop ... 22&t=25346 which advised there were some delays, in the mean time I will just utilize NTSI 1.4.
Thanks again slansing for all your help and support, you may close the thread as resolved as I will be looking at the previous nagios post for updates.
And thanks again for this amazing product! I will soon be supporting it :)
Sincerely,
Michael
