Google Map Dashlet
MSPk
Google Map Dashlet
Post by MSPk »
Hi Team,
We have installed Google Map dashlet and added multiple servers for a location same co-ordinates, when we check the map we only see one server(that was added first) and information of other servers is not visible on the map. Is it supposed to work that way? can you please suggest how we can get the info of all the servers in the map.
Re: Google Map Dashlet
First I would make sure that the server coordinates are properly-written, since I remember that being an issue if you have a space or something before the latlng field. It is very particular.
