host down/service up
cesar.garza
Post by cesar.garza »
yoyo nagios !!
Guy i have setup few host and service and got the really weird situation here that host is showing down(Red) and services are up(green). I dont know its a bug or what. I have attached a screenshot.
Let me know if anyone has a update or facing same issue.
abrist
Red Shirt
Re: host down/service up
Post by abrist »
Can we see the configs? Either the services are actually running on the wrong host, or your host is actually UP, but the host check is failing . . . .
cesar.garza
This is the way i configured my host.cfg for 100 box and only two is throwing host down. even though i can login into the boxes.
            use                 generic-host
            check_command       check-host-alive
            max_check_attempts  4
            host_name           stga-mongodb-hkg01
            alias               stga-mongodb-hkg01
            address             10.11.170.24
            hostgroups          mongodb
What message is displayed in the Status Information column for the down hosts? I want to see what output the host check is returning.
cesar.garza
I just found out that my network team disabled the ping into that box. Now nagios able to ping that box and getting reply.
Thanks to jump on it.
Post by slansing »
So your host checks are working fine now? Do you have further questions on this?
cesar.garza
Yes, I am good on it.
thanks
