Has anybody tried installing Nagios XI on an existing Nagios Core server?
From the recommendation, it prefer to be a clean system and requires internet access so was wondering, can we install/upgrade offline without internet?
Thx
Kk
Nagios XI Installation with existing Nagios Core
cheungkokkeong
Re: Nagios XI Installation with existing Nagios Core
Upgrading from Core to XI, you would want to start with a new clean server, install XI and then import the core config files
http://library.nagios.com/library/produ ... es-into-xi
cheungkokkeong
Hi Scott,scottwilkerson wrote:Upgrading from Core to XI, you would want to start with a new clean server, install XI and then import the core config files
Yes, had read on that but due to certain reasons, is it possible to install on a existing nagios core server.
Thx
No, it is not possible, there are a lot of things that could go wrong and that would in turn make both systems unsupportable by us. The best way to do this would be to use one of our VM's, or build a source installed XI server up.
cheungkokkeong
Hi,slansing wrote:No, it is not possible, there are a lot of things that could go wrong and that would in turn make both systems unsupportable by us. The best way to do this would be to use one of our VM's, or build a source installed XI server up.
Noted, thx.
