It dose not properly escape them. Treating the reset of the line as a comment.
Tried using /usr/local/nagios/etc/resource.cfg
$USER9$=secr#et
Editing in the CCM it escapes the $. $USER9$ to \$USER9\$
How do i use a password with a #, pound symbol, hash?
Nagios XI 2012R2.3
passwords with #, pound symbol, hash
Re: passwords with #, pound symbol, hash
I believe this should work
One thing I will mention, if you are using the "Test Command" in the CCM it will not work as it does not import the $USERn$ vars, you will actually have to save the host/service and let the check run.
$USER9$='secr#et'Re: passwords with #, pound symbol, hash
Thanks.
Yep was trying the "Test Command".
After editing /usr/local/nagios/etc/resource.cfg do I need to restart anything for it to load the new/edited variables?
Ended up making a new Command (CCM > Commands > Command) with the password in it.
