Some weeks ago, I deleted an old host from Nagios Core. I've now been asked for an availability report on some of its services, but I am not able to select it. Is there an easy way to produce this data, or has its history effectively been deleted when I removed the host?
Paul.
Availability report for deleted server
Re: Availability report for deleted server
You should still have viability of it in your archived nagios logs, at the location of your current nagios log/archives. You could potentially try re-adding the host to see if you would be able to grab that old data from the web UI. I've never personally tried this.
