I'm going through the trial version of the latest NagiosXI version and don't see the Deploy Dashboard option. Is there a configuration I missed?
thanks!
Deploy Dashboard option not available
Re: Deploy Dashboard option not available
Are you looking under the Dashboards tab? Post a screenshot if it will help clarify.
All that is available when logging in as the administrator under Dashboard Tools is Add New Dashboard.
You can add it with the attached zip through, Admin -> Manage Components
check! worked like a champ, thank you.
