reset wmi performance counter \\System\\Error Login
hohum
Post by hohum »
I have a critical on "Logon Errors"
$USER1$/check_nt -H $HOSTADDRESS$ -s "$ARG1$" -p 12489 -v $ARG2$ $ARG3$ $ARG4$
$ARG1$ = password-not telling :)
$ARG2$ = COUNTER
$ARG3$ = -l "\\Server\\Errors Logon","Login Errors since last reboot is %.f" -w 2 -c 20
There's been 395 login errors since last reboot. This is a fantastic monitor. But I'd like to be able to reset the counter to clear the alert without rebooting. That doesn't sound possible. Am I right? Google is not helping.
- Marc
sreinhardt
-fno-stack-protector
Re: reset wmi performance counter \\System\\Error Login
Post by sreinhardt »
Unfortunately short of rebooting or resetting all performance counters on the system back to their base values, there is not much if anything that I know of to reset an individual counter. The one or two things I do know of, I would not suggest using on a production box. Might this be something you would be better off writing a wrapper script to store the last value(s) and compare with a difference between the two checks?
