Can not delete service?
I want to delete a service(Oracle Query - MAP_EVENT), but I can't find on Service Management Page in CCM?
Re: Can not delete service?
Search for MAP_EVENT instead of the server's IP
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
sreinhardt
- -fno-stack-protector
Also I would suggest using the New CCM instead of the old, unless you absolutely must use the old one for some reason.
Already new CCM.sreinhardt wrote:Also I would suggest using the New CCM instead of the old, unless you absolutely must use the old one for some reason.
We already using that, still can't.BanditBBS wrote:Search for MAP_EVENT instead of the server's IP
Do you have any other checks configured with the name "MAP_EVENT"? If so, it could be an inherited check from a hostgroup, or it could be directly assigned to more than one host.
1) Search the CCM for "MAP_EVENT" for all services (do not restrict the search to just one host).
2) If MAP_EVENT checks exist, check each of them for extra host or hostgroup assignments.
3) If still not resolved, run the following and post the output:
grep "MAP_EVENT" /usr/local/nagios/etc/services/*Former Nagios employee
