E A S Y question!
benhank
E A S Y question!
Post by benhank »
fellas!
how do I change this script:
/usr/local/nagiosxi/scripts/backup_xi.sh
so that it excludes the perfdata directory (I don't want to include the perfdata in my backup)? (and don't say "Google" spence...
Proudly running:
Nagios Network Analyser
Nagios Fusion
Re: E A S Y question!
benhank wrote:(and don't say "Google" spence...
The Trevor will say it: Google!
http://stackoverflow.com/questions/9842 ... es-folders
You'll just need to exclude the directory you want. Are you looking to exclude the RRDs or the unprocessed perfdata?
Also, update your signature. Seeing 1.6 is making me uneasy.
abrist
Red Shirt
Post by abrist »
Update yo' signature! R1.6?
Post by slansing »
I'd also recommend that you update your signature :)
sreinhardt
-fno-stack-protector
Post by sreinhardt »
1.6? man time to update that nagios box!
benhank
Post by benhank »
alright alright sheesh....
its this one
/usr/local/nagios/share/perfdata
it's 39 gigs over here!
Proudly running:
Nagios Fusion
abrist
Red Shirt
Post by abrist »
In /usr/local/nagiosxi/scripts/backup-xi.sh, change line #84 from:
tar czfps $mydir/nagios.tar.gz /usr/local/nagios
To:
tar czfps $mydir/nagios.tar.gz tar --exclude='/usr/local/nagios/share/perfdata' /usr/local/nagios
That should help keep the size of the backup down. If you care about the perfdata, just tar it up every once in a while and overwrite the old perfdata tar.
benhank
Post by benhank »
THANKS!
Does my new sig make me look fat?
Lock er up fellas i is be all set!
Proudly running:
Nagios Fusion
abrist
Red Shirt
Post by abrist »
You really should think about moving to windows me for the personal touch or os/2 warp for the street cred.
benhank
Post by benhank »
windowsme? we dont need no newfangled os's. next thing you know you will be telling me to bump my ram up to 4mb's, no sir we are good. lock er up fellas!
Proudly running:
Nagios Fusion
