Try replacing all of your literal newline and carriage returns (`r`n) with the linux\C version (\r\n). This should put the entire line on a single line for nrpe to return and when interpreted and put into notifications or the nagios screen, it will show actual newlines but should also show everything in your message.
Also, you might not even need the \r any longer.
Output goes from:
PS> .\willem.ps1 localhost '' ''
All 0 tasks ran succesfully!
| 'Total Tasks'=0, 'OK Tasks'=0, 'Failed Tasks'=0, 'Running Tasks'=0
To:
All 0 tasks ran succesfully!\r\n | 'Total Tasks'=0, 'OK Tasks'=0, 'Failed Tasks'=0, 'Running Tasks'=0
The changed code looks like:
# Script name: check_ms_win_tasks.ps1
# Version: 2.14.4.11
# Created on: 01/02/2014
# Author: D'Haese Willem
# Purpose: Checks Microsoft Windows scheduled tasks excluding defined folders and defined
# task patterns, returning state of tasks with name, author, exit code and
# performance data to Nagios.
# On Github: https://github.com/willemdh/check_ms_win_tasks.ps1
# To do:
# - Add switches to change returned values and output
# - Add array parameter with exit codes that should be excluded
# - Make parameters non mandatory
# - Test remote execution
# History:
# 03/02/2014 => Add array as argument with excluded folders
# 15/02/2014 => Add array as argument with excluded task patterns
# 03/03/2014 => Added perfdata and edited output
# 09/03/2014 => Added running tasks information and perfdata
# 22/03/2014 => Resolved a bug with output treated as perfdata
# 23/03/2014 => Created repository on Github and updated documentation
# 11/04/2014 => New output format with outputstring to be able to see failed tasks in service history
# 11/04/2014 => Added [int] to prevent decimal numbers
# How to:
# 1) Put the script in the NSCP scripts folder
# 2) In the nsclient.ini configuration file, define the script like this:
# check_ms_win_tasks=cmd /c echo scripts\check_ms_win_tasks.ps1 $ARG1$ $ARG2$ $ARG3$; exit
# $LastExitCode | powershell.exe -command -
# 3) Make a command in Nagios like this:
# check_ms_win_tasks => $USER1$/check_nrpe -H $HOSTADDRESS$ -p 5666 -t 60 -c
# check_ms_win_tasks -a $ARG1$ $ARG2$ $ARG3$
# 4) Configure your service in Nagios:
# - Make use of the above created command
# - Parameter 1 should be 'localhost' (did not test with remoting)
# - Parameter 2 should be an array of folders to exclude, example 'Microsoft, Backup'
# - Parameter 3 should be an array of task patterns to exclude, example 'Jeff,"Copy Test"'
# - All single quotes need to be included (In Nagios XI)
# - Array values with spaces need double quotes (see above example)
# - All three parameters are mandatory for now, use " " if you don't want exclusions
# Help:
# This script works perfectly in our environment on Windows 2008 and Windows 2008 R2 servers. If
# you do happen to find an issue, let me know on Github. The script is highly adaptable if you
# want different output etc. I've been asked a few times to make it multilingual, as obviously
# this script will only work on English Windows 2008 or higher servers, but as I do not have
# non-English servers at my disposal, I'm not going to implement any other languages..
# Copyright:
# This program is free software: you can redistribute it and/or modify it under the terms of the
# GNU General Public License as published by the Free Software Foundation, either version 3 of
# the License, or (at your option) any later version.
# This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY;
# without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
# See the GNU General Public License for more details.You should have received a copy of the GNU
# General Public License along with this program. If not, see <http://www.gnu.org/licenses/>.
param(
[Parameter(Mandatory=$true)][string]$ComputerName = "localhost",
[Parameter(Mandatory=$true)]$ExclFolders = @(),
[Parameter(Mandatory=$true)]$ExclTasks = @(),
[switch]$RootFolder
#region Functions
function Get-AllTaskSubFolders {
[cmdletbinding()]
param (
$FolderRef = $Schedule.getfolder("\")
if ($RootFolder) {
$FolderRef
} else {
$FolderRef
if(($folders = $folderRef.getfolders(1)).count -ge 1) {
foreach ($folder in $folders) {
if ($ExclFolders -notcontains $folder.Name) {
if(($folder.getfolders(1).count -ge 1)) {
Get-AllTaskSubFolders -FolderRef $folder
else {
$folder
function Check-Array ([string]$str, [string[]]$patterns) {
foreach($pattern in $patterns) { if($str -match $pattern) { return $true; } }
return $false;
#endregion Functions
if ($PSVersionTable) {$Host.Runspace.ThreadOptions = 'ReuseThread'}
$status = 3;
try {
$schedule = new-object -com("Schedule.Service")
} catch {
Write-Host "Schedule.Service COM Object not found, this script requires this object"
exit $status
return
$Schedule.connect($ComputerName)
$AllFolders = @()
$AllFolders = Get-AllTaskSubFolders
[int]$TaskOk = 0
[int]$TaskNotOk = 0
[int]$TaskRunning = 0
[int]$TotalTasks = 0
$BadTasks = @()
$GoodTasks = @()
$RunningTasks = @()
$OutputString = ""
foreach ($Folder in $AllFolders) {
if (($Tasks = $Folder.GetTasks(0))) {
$Tasks | Foreach-Object {$ObjTask = New-Object -TypeName PSCustomObject -Property @{
'Name' = $_.name
'Path' = $_.path
'State' = $_.state
'Enabled' = $_.enabled
'LastRunTime' = $_.lastruntime
'LastTaskResult' = $_.lasttaskresult
'NumberOfMissedRuns' = $_.numberofmissedruns
'NextRunTime' = $_.nextruntime
'Author' = ([xml]$_.xml).Task.RegistrationInfo.Author
'UserId' = ([xml]$_.xml).Task.Principals.Principal.UserID
'Description' = ([xml]$_.xml).Task.RegistrationInfo.Description
'Cmd' = ([xml]$_.xml).Task.Actions.Exec.Command
'Params' = ([xml]$_.xml).Task.Actions.Exec.Arguments
if ($ObjTask.LastTaskResult -eq "0") {
if(!(Check-Array $ObjTask.Name $ExclTasks)){
$GoodTasks += $ObjTask
$TaskOk += 1
elseif ($ObjTask.LastTaskResult -eq "0x00041301") {
$RunningTasks += $ObjTask
$TaskRunning += 1
else {
$BadTasks += $ObjTask
$TaskNotOk += 1
$TotalTasks = $TaskOk + $TaskNotOk + $TaskRunning
if ($TaskNotOk -gt "0") {
$OutputString += "$TaskNotOk / $TotalTasks tasks failed! Check tasks: \r\n"
foreach ($BadTask in $BadTasks) {
$OutputString += "Task $($BadTask.Name) by $($BadTask.Author) failed with exitcode $($BadTask.lasttaskresult)\r\n"
foreach ($RunningTask in $RunningTasks) {
$OutputString += "Task $($RunningTask.Name) by $($RunningTask.Author), exitcode $($RunningTask.lasttaskresult) is still running!\r\n"
$OutputString += " | 'Total Tasks'=$TotalTasks, 'OK Tasks'=$TaskOk, 'Failed Tasks'=$TaskNotOk, 'Running Tasks'=$TaskRunning"
$status = 2
else {
$OutputString += "All $TotalTasks tasks ran succesfully!\r\n"
$status = 0
Write-Host "$outputString"
exit $status
