Nagios XI R2.9 SNMP traps receive shows "Waiting for trap.."
pshaw1
Post by pshaw1 »
I followed the instructions in http://assets.nagios.com/downloads/nagi ... ios_XI.pdf. No errors.
Created a device and added the SNMP Trap service to it. Under the status information, it only says "Waiting for trap...".
I checked /var/log/messages and /var/log/snmp/snmptt.log and I see the snmp traps coming in.
I am using snmptt-1.4-0.9.beta2.el6.noarch. I tried using snmptt-1.3-3.nagios.noarch.rpm but when I did, it didn't add the snmptt user and the script failed when trying to add that user to the nagcmd and nagios group.
sreinhardt
-fno-stack-protector
Re: Nagios XI R2.9 SNMP traps receive shows "Waiting for tra
Post by sreinhardt »
Well, let's start of with some basic information and move on from there. Also I should ask, are you presently on 1.3 or 1.4? I would suggest the latter.
Versions installed
    rpm -qa | grep snmp
Looking for bins:
    ls -lva /usr/local/bin | grep -i 'snmp\|addmib'
    ls -lva /usr/local/sbin | grep -i 'snmp\|addmib'
    ls -lva /usr/sbin | grep -i 'snmp\|addmib'
    cat /etc/snmp/snmptrapd.conf
snmptt\trapd settings and user perms:
    grep -i 'daemon_uid\|mode =' /etc/snmp/snmptt.ini
    grep -i 'exec' /etc/snmp/snmptt.conf | tail -n 10
    grep -i 'nag' /etc/group
    grep -i 'snmp' /etc/group
Checking log and spool dirs:
    ll /var/log/snmptt/
    ll -d /var/log/snmptt/
    ll /var/spool/snmptt
    ll -d /var/spool/snmptt
pshaw1
Post by pshaw1 »
# rpm -qa | grep snmp
net-snmp-utils-5.5-49.el6_5.1.x86_64
net-snmp-libs-5.5-49.el6_5.1.x86_64
net-snmp-perl-5.5-49.el6_5.1.x86_64
net-snmp-5.5-49.el6_5.1.x86_64
php-snmp-5.3.3-27.el6_5.x86_64
So running snmptt-1.4-0.9.beta2.el6.noarch
# ls -lva /usr/local/bin/ | grep -i 'snmp\|addmib'
-rwxr-xr-x   1 root nagios      804 Apr  3 12:09 addmib
-rwxr-xr-x   1 root root       2078 Apr  3 12:09 snmptraphandling.py
-rwxr-xr-x   1 root root      30438 Apr  3 12:09 snmpttconvertmib
No bins matching in /usr/local/sbin
# ls -lva /usr/sbin | grep -i 'snmp\|addmib'
-rwxr-xr-x.  1 root root       30744 Mar  6 12:51 snmpd
-rwxr-xr-x.  1 root root       30776 Mar  6 12:51 snmptrapd
-rwxr-xr-x   1 root root      177466 Oct 22  2012 snmptt
-rwxr-xr-x   1 root root        6493 Oct 22  2012 snmptthandler
# cat /etc/snmp/snmptrapd.conf
disableAuthorization yes
traphandle default /usr/sbin/snmptthandler
# grep -i 'daemon_uid\|mode =' /etc/snmp/snmptt.ini
mode = daemon
description_mode = 0
# A second (child) process will be started as the daemon_uid user so
daemon_uid = snmptt
# grep -i 'exec' /etc/snmp/snmptt.conf | tail -n 10
#EXEC qpage -f TRAP notifygroup1 "Device reinitialized (coldStart)"
#EXEC qpage -f TRAP notifygroup1 "Device reinitialized (warmStart)"
#EXEC qpage -f TRAP notifygroup1 "Link down on interface $1.  Admin state: $2.  Operational state: $3"
#EXEC qpage -f TRAP notifygroup1 "Link up on interface $1.  Admin state: $2.  Operational state: $3"
#EXEC qpage -f TRAP notifygroup1 "SNMP authentication failure"
# grep -i 'nag' /etc/group
nagios:x:501:nagios,apache,snmptt
nagcmd:x:502:nagios,apache,snmptt
# grep -i 'snmp' /etc/group
snmptt:x:489:
# ll /var/log/snmptt/
total 36
-rw-rw-r-- 1 snmptt snmptt  8252 Apr  3 14:07 snmptt.log
-rw-rw-r-- 1 snmptt snmptt  4679 Apr  3 13:52 snmpttsystem.log
-rw-rw-r-- 1 snmptt root   13863 Apr  3 13:58 snmpttunknown.log
# ll -d /var/log/snmptt/
drwxrwxr-x 2 snmptt snmptt 4096 Apr  3 12:19 /var/log/snmptt/
# ll /var/spool/snmptt
total 0
# ll -d /var/spool/snmptt
drwxrwxr-x 2 snmptt snmptt 4096 Apr  3 14:07 /var/spool/snmptt
# tail /var/log/snmptt/snmptt.log
Thu Apr  3 14:13:34 2014 .1.3.6.1.6.3.1.1.5.3 Critical "Status Events" testswitch - Link down on interface 10101.  Admin state: GigabitEthernet1/0/1.  Operational state: ethernetCsmacd
Thu Apr  3 14:13:49 2014 .1.3.6.1.6.3.1.1.5.4 Normal "Status Events" testswitch - Link up on interface 10101.  Admin state: GigabitEthernet1/0/1.  Operational state: ethernetCsmacd
In Nagios, the device had a domain at the end of it and I noticed in the log above it didn't, so I renamed the device in Nagios and that didn't fix it. I also added in the snmptt.ini the domains to strip just in case.
sreinhardt
The reason you are not getting these in the nagios interface, but they are considered known traps, is that these two traps do not have proper exec lines within snmptt.conf.
On my system that same command looks like:
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "The SNMP trap that is generated as a result of an event with the host $*"
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "The SNMP trap that is generated as a result of an event requiring $*"
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "The SNMP trap that is generated as a result of an event with the service $*"
A simple way to resolve this would be to add exec lines directly under the commented out ones, something like this should do:
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "Link down on interface $1.  Admin state: $2.  Operational state: $3"
AND
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "Link up on interface $1.  Admin state: $2.  Operational state: $3"
You then need to restart snmptt with: service snmptt restart
pshaw1
Post by pshaw1 »
Worked!
Note: with the domain names stripped, the alarm wouldn't stay and would get a
SERVICE ALERT: testswitch;SNMP Traps;OK;HARD;1;OK: TRAP RESET
without another trap received.
So I renamed the device back with the domain and turned off domain stripping in snmptt.ini and now the alarms stay.
Thank you very much for your help!
