Deployment not possible due to errors in configuration
yuijhbnm
Post by yuijhbnm »
i use Nconf ,when i del the default host
Generate Nagios config
display this error:
Deployment not possible due to errors in configuration.
Nagios Core 4.0.4
Last Modified: 03-14-2014
License: GPL
Reading configuration data...
Read main config file okay...
Error: Service has no hosts and/or service_description (config file '/var/www/html/nconf/temp/Default_collector/advanced_services.cfg', starting on line 79)
***> The name of the main configuration file looks suspicious...
Make sure you are specifying the name of the MAIN configuration file on
the command line and not the name of another configuration file. The
main configuration file is typically '/usr/local/nagios/etc/nagios.cfg'
                service_description                   PING
                check_command                         check_ping!100.0,20%!500.0,60%
                hostgroup_name                        linux-servers
                use                                   local-service
                contact_groups                        +admins
                service_description                   Current Users
                check_command                         check_local_users!20!50
                use                                   local-service
                service_description                   Total Processes
                check_command                         check_local_procs!250!400!RSZDT
                use                                   local-service
                service_description                   Current Load
                check_command                         check_local_load!5.0,4.0,3.0!10.0,6.0,4.0
                use                                   local-service
                service_description                   Swap Usage
                check_command                         check_local_swap!20!10
                use                                   local-service
                service_description                   SSH
                notifications_enabled                 0
                check_command                         check_ssh!
                use                                   local-service
                service_description                   HTTP
                check_command                         check_http!
                servicegroups                         web-services
                use                                   local-service
                check_interval                        10
                retry_interval                        1
                check_command                         check_ping!3000.0,80%!5000.0,100%
                hostgroup_name                        network-printers
                use                                   generic-service
                check_interval                        5
                retry_interval                        1
                check_command                         check_ping!200.0,20%!600.0,60%
                hostgroup_name                        switches
                use                                   generic-service
                service_description                   Uptime
                check_command                         check_snmp!-C public -o sysUpTime.0
                use                                   generic-service
                service_description                   NSClient++ Version
                check_command                         check_nt!CLIENTVERSION
                hostgroup_name                        windows-servers
                use                                   generic-service
                check_command                         check_nt!UPTIME
                use                                   generic-service
                service_description                   CPU Load
                check_command                         check_nt!CPULOAD!-l 5,80,90
                use                                   generic-service
                service_description                   Memory Usage
                check_command                         check_nt!MEMUSE!-w 80 -c 90
                use                                   generic-service
                service_description                   C:\ Drive Space
                check_command                         check_nt!USEDDISKSPACE!-l c -w 80 -c 90
                use                                   generic-service
                service_description                   Explorer
                check_command                         check_nt!PROCSTATE!-d SHOWALL -l Explorer.exe
                use                                   generic-service
Re: Deployment not possible due to errors in configuration
These services are including a hostgroup linux-servers
If linux-servers hostgroup doesn't have any hosts in it, it will in fact throw the error you describe...
