CISCO ASA plugin CPU load issue
kalyan1709
Post by kalyan1709 »
Hi Team,
I am getting a below alert from Nagios frequently:
***** Nagios *****
Notification Type: PROBLEM
Service: System Load
Host: Main Firewall
Address: 10.1.124.1
State: CRITICAL
Date/Time: Thu Apr 3 12:23:59 XXX 2014
Additional Info:
Cisco ASA CPU : 5sec = 6 %, 2min = 8 %, 5min = 4294965 % : 4294965 50 : CRITICAL
From this alert the 5min % is showing wrong (5min = 4294965 %)
Below is my Command definition
command_name check_Cisco_CPU
command_line $USER1$/check_cisco_ips.pl -H $HOSTADDRESS$ -2c -C default -f -T cpu -w 70%,50%,40% -c 90%,70%,50%
I have attached the plugin which I used.
Can anyone suggest me to fix these unwanted alerts?
check_cisco_ips.pl
(17 KiB) Downloaded 480 times
Re: CISCO ASA plugin CPU load issue
What model number are you using? The plugin author specified he tested on a 5520. Your OIDs may be different.
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Let's try seeing what is at that oid, my guess would be, that the plugin expecting something quite different than what the device is sending.
snmpwalk -O n -v 2c -c default 10.1.124.1 1.3.6.1.4.1.9.9.109.1.1.1.1.5.1
kalyan1709
Mine is ASA_5510. Is there any plugin for this model to monitor CPU System load.
sreinhardt
Well it certainly seems that most of the information is there, let's try running those commands I posted and see what we get.
kalyan1709
[root@nagios ~]# snmpwalk -O n -v 2c -c default 10.1.124.1 1.3.6.1.4.1.9.9.109.1.1.1.1.5.1
.1.3.6.1.4.1.9.9.109.1.1.1.1.5.1 = Gauge32: 8
.1.3.6.1.4.1.9.9.109.1.1.1.1.2.1 = INTEGER: 1
.1.3.6.1.4.1.9.9.109.1.1.1.1.2.2 = INTEGER: 1
.1.3.6.1.4.1.9.9.109.1.1.1.1.2.3 = INTEGER: 1
.1.3.6.1.4.1.9.9.109.1.1.1.1.3.1 = Gauge32: 14
.1.3.6.1.4.1.9.9.109.1.1.1.1.3.2 = Gauge32: 14
.1.3.6.1.4.1.9.9.109.1.1.1.1.3.3 = Gauge32: 14
.1.3.6.1.4.1.9.9.109.1.1.1.1.4.1 = Gauge32: 8
.1.3.6.1.4.1.9.9.109.1.1.1.1.4.2 = Gauge32: 8
.1.3.6.1.4.1.9.9.109.1.1.1.1.4.3 = Gauge32: 8
.1.3.6.1.4.1.9.9.109.1.1.1.1.5.2 = Gauge32: 8
.1.3.6.1.4.1.9.9.109.1.1.1.1.5.3 = Gauge32: 8
.1.3.6.1.4.1.9.9.109.1.1.1.1.9.1 = Gauge32: 5
.1.3.6.1.4.1.9.9.109.1.1.1.1.9.2 = Gauge32: 5
.1.3.6.1.4.1.9.9.109.1.1.1.1.9.3 = Gauge32: 5
.1.3.6.1.4.1.9.9.109.1.1.1.1.10.1 = Gauge32: 14
.1.3.6.1.4.1.9.9.109.1.1.1.1.10.2 = Gauge32: 14
.1.3.6.1.4.1.9.9.109.1.1.1.1.10.3 = Gauge32: 14
.1.3.6.1.4.1.9.9.109.1.1.1.1.11.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.109.1.1.1.1.11.2 = Gauge32: 0
.1.3.6.1.4.1.9.9.109.1.1.1.1.11.3 = Gauge32: 0
sreinhardt
Well that's strange, it seems that it reports a perfectly normal number, and the plugin does not math to modify the value that would be displayed here. Let's remove your % signs from the command and try running it via cli, since the plugin really doesn't have a % of load. Also how often is this happening, all the time, once in a while, almost never?
./check_cisco_ips.pl -H 10.1.124.1 -2c -C default -f -T cpu -w 70,50,40 -c 90,70,50
./check_cisco_ips.pl -H 10.1.124.1 -2c -C default -f -T cpu -w 70%,50%,40% -c 90%,70%,50%
kalyan1709
[root@nagios libexec]# ./check_cisco_ips.pl -H 10.1.124.1 -2c -C default -f -T cpu -w 70,50,40 -c 90,70,50
Cisco ASA CPU : 5sec = 8 %, 2min = 8 %, 5min = 8 % : OK | load_5_sec=8%;70;90 load_1_min=8%;50;70 load_5_min=8%;40;50
[root@nagios libexec]# ./check_cisco_ips.pl -H 10.1.124.1 -2c -C default -f -T cpu -w 70%,50%,40% -c 90%,70%,50%
Cisco ASA CPU : 5sec = 10 %, 2min = 8 %, 5min = 8 % : OK | load_5_sec=10%;70;90 load_1_min=8%;50;70 load_5_min=8%;40;50
sreinhardt
OK so the % signs have no bearing on the output. However since this is working now, would I be correct in understanding this is an intermittent issue?
kalyan1709
Yes, The wrong % is triggering in week or a months or not regularly.
I wonder where is the problem exactly !!! ?
