This works fine, I can see the hosts and services fine in host/service detail on Nagiosxi.
My problem is that they dont show up in CCM so if I need to do a small tweek to a serivce or host, they are not there.
I know I can go into CCM and 'import config' but my question is... is there any way nagiosXI allows me to do this within my script?
For example with the old nagios core cfg files you could use:
php /usr/local/nagiosxi/tools/xiprepimport.php orig/host.cfg to convert into proper xi format/layout.
(not sure if you still needed to use 'import config' or not.
So I'm looking for some way for me to import the config files without using the GUI(As I may have 100+ hosts, doing this manaully in the GUI would take too much of my time)...
Any help would be appreciated!
Disclaimer89
