localhost Config Verification
KnightWolfJK
Post by KnightWolfJK »
I've googled and looked through the FAQ. I think I screwed up with something regarding the localhost configuration, and now I'm having a lot of intermittent issues.
For starters, here's the output of my config verification, trimmed to only show the errors:
[root@nagiosvdi ~]# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 3.5.0
Last Modified: 03-15-2013
License: GPL
Reading configuration data...
   Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config directory '/usr/local/nagios/etc/hosts'...
Processing object config file '/usr/local/nagios/etc/hosts/192.168.101.238.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/NagiosVDI.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Brother Printer.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/192.168.101.239.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/JKTUXBEAST.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/ASUS Router.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/JKWINBEAST.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/BRN001BA943B025.cfg'...
Processing object config directory '/usr/local/nagios/etc/services'...
Processing object config file '/usr/local/nagios/etc/services/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/services/192.168.101.238.cfg'...
Processing object config file '/usr/local/nagios/etc/services/NagiosVDI.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Brother Printer.cfg'...
Processing object config file '/usr/local/nagios/etc/services/192.168.101.239.cfg'...
Processing object config file '/usr/local/nagios/etc/services/JKTUXBEAST.cfg'...
Processing object config file '/usr/local/nagios/etc/services/ASUS Router.cfg'...
Processing object config file '/usr/local/nagios/etc/services/JKWINBEAST.cfg'...
Processing object config file '/usr/local/nagios/etc/services/BRN001BA943B025.cfg'...
Error: Could not find any host matching 'localhost' (config file '/usr/local/nagios/etc/hostgroups.cfg', starting on line 14)
Error: Could not expand members specified in hostgroup (config file '/usr/local/nagios/etc/hostgroups.cfg', starting on line 14)
So there are a lot of host CFG files, yet I deleted those hosts long ago via CCM... See attachments, which show hosts being monitored without hosts being configured. Any ideas? I tried this but I'm not manually editing things.
abrist
Red Shirt
Re: localhost Config Verification
Post by abrist »
Did you remove the "localhost" checks? We usually suggest that you do not remove these checks as they are checking the nagios server itself and will warn you when your disk is filling up etc. It appears as if you need to remove references to "localhost" from one of your hostgroups. If you do not have many hostgroups, just look through them and remove "localhost" from any that you find. Or, just check the config file: /usr/local/nagios/etc/hostgroups.cfg - line #14 to see which hostgroup "localhost" is still associated with.
KnightWolfJK
Thanks, tried that as well- the hosts still appear even though they've been deleted, and the discovery engine errors out when I edit the file. Instead, I swapped to another enterprise monitoring system yesterday.
