Tried searching but couldn't find anything.
I'm using the 'check_mostrecentfile.vbs' plugin and it works a treat! However when specifying a path to the directory with spaces in, it complains about not passing in the required 4 arguments (directory, warning, critical, size)
This fails:
[root@svlvpoc001 plugins]# ./check_nrpe -H IP -p 5666 -c check_mostrecentfile -a c:/test log/ 50 60 1
enter a valid Warning age (minutes): i.e. 1440
This works:
[root@svlvpoc001 plugins]# ./check_nrpe -H IP -p 5666 -c check_mostrecentfile -a c:/temp/ 50 60 1
CRITICAL: test.txt is 2355 minutes old.
I know the unix shell has some oddities with / and the like but have tried so many different iterations without any success.
Anyone got any ideas?
Command Definition with Spaces?
Re: Command Definition with Spaces?
Have you tried
./check_nrpe -H IP -p 5666 -c check_mostrecentfile -a "c:/test log/" 50 60 1
peakyblinder
Finally figured this out in the meantime but thanks for your input.prandal wrote:Have you tried
I put "" around the first "$ARG1$" like this;
command_name check_mostrecentfile
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -p 5666 -c check_mostrecentfile -a "$ARG1$" $ARG2$ $ARG3$ $ARG4$
The Service looks like this;
host_name BCC009413
service_description Check File Age
check_command check_mostrecentfile!C:/Benefits/DWPDataXfer/TEST Log/!26!30!1
check_interval 2
retry_interval 2
max_check_attempts 3
Post can be closed.
