How to use following Nagios feature mentioned in version log 3.3.1
#Added ability to authenticate to CGIs using contactgroup name
I am using very latest Nagios version 3.5.1 on my test machine.
I have test a lot , but can not find its solution
I have added one host , contact & contact group , assigned contact group to that host & created one user same as contactgroup & tried to login , Login is successful but that user can not able to see that host & its services.
Please help me if anyone having any idea.
Madhukar
Mod Note: Moved to General Core Support Forums
sreinhardt
- -fno-stack-protector
Re: Added ability to authenticate to CGIs using contactgroup
I was able to create a new contact group and contact(named the same thing cg-test), add this contact to the group, then only add the contact group, to an existing host. I then logged in as this new contact, that had no rights and was attached directly to no hosts or services, only the contact group. I was successfully able to view the host, but not the services.
I then removed the contact from the group, and removed the contact entirely. Refreshed the page, and validated, that I had the same functionality of neither hosts nor services showing. Which is the same as you.
However I believe the changelog is really referring to the first case where the contact group has a contact, and that is really what you are authenticating as via proxy with the contact group. I will have to speak with the devs if this is actually intended or not.
sreinhardt
I have not had a chance to speak with that particular developer. Could you confirm if this is the behavior you are expecting to see or not?
I need contactgroup name can login on nagios web interface & see only hosts & services which they are added for notification.
Are you using the correct authorized_contactgroup_for_* directives in cgi.cfg? Or are you just adding the contactgroups to the standard authorized_for_* directives?
authorized_contactgroup_for_all_hosts=
authorized_contactgroup_for_all_services=
authorized_contactgroup_for_system_information=
authorized_contactgroup_for_configuration_information=
authorized_contactgroup_for_all_host_commands=
authorized_contactgroup_for_all_service_commands=
authorized_contactgroup_for_system_commands=
authorized_contactgroup_for_read_only=
i was using standard authorized_for_* directives, I will test authorized_contactgroup_for_* directives in cgi.cfg in my nagios & let you know.
No problem. I don't think these new options are really documented yet. I will open up a bug report for them:
http://tracker.nagios.org/view.php?id=607
