Hi all!
I'm trying to install NRPE on a Linux (RH-EL6) machine that does not have internet access (security issues).
I'm following the procedures listed under Support forum
http://support.nagios.com/forum/viewtop ... 2&start=10
However I am encountering an issue (listed below)
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './A-subcomponents'
The install.log is attached.
Install NRPE - no internet access
Re: Install NRPE - no internet access
You are going to need a compiler on that system, namely 'gcc' which it does not look like you have.
