Im kind of stuck, I have a cisco switch I want to monitor the bandwidth of an interface.
I added the interface to the host via a wizard, it remained at 0in 0 out.
All other stats to this device work even bandwidth to other interfaces
I deleted the services / host and redid the whole lot. Same as above.
I used another monitoring solution to monitor the interface - works...
Any ideas why I cannot get the bandwidth on this interface?
Bandwidth 0 in 0 out
Re: Bandwidth 0 in 0 out
What is the Nagios XI version that you are currently using?
Can you show us the actual command that you are running from the CLI along with the output of it? For example:
Do you get any errors when you run the following command?
Run the following commands and show us the output:
/usr/local/nagios/libexec/check_rrdtraf -f /var/lib/mrtg/192.168.x.x_1.rrd -w 200,200 -c 500,500 -l M
OK - Current BW in: 3.61Mbps Out: .54Mbps|in=3.618163Mb/s;200;500 out=.542662Mb/s;200;500Code: Select all
LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfgCode: Select all
ll -d /etc/mrtg
ll /etc/mrtgDid you follow the steps, outlined in this document?I deleted the services / host and redid the whole lot. Same as above.
Version : 2012R2.9
Mod Note: Please use code wraps for this, not quote wraps
[root@nagios ~]# /usr/local/nagios/libexec/check_rrdtraf -f /var/lib/mrtg/11.10.0.254_10102.rrd -w 200,200 -c 500,500 -l M
OK - Current BW in: 0Mbps Out: 0Mbps|in=0Mb/s;200;500 out=0Mb/s;200;500Code: Select all
[root@nagios ~]# LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg
SNMP Error:
no response received
SNMPv1_Session (remote host: "10.10.0.25" [10.10.0.25].161)
community: "public"
request ID: 926039699
PDU bufsize: 8000 bytes
timeout: 2s
retries: 5
backoff: 1)
at /usr/bin/../lib64/mrtg2/SNMP_util.pm line 492
SNMPGET Problem for ifInOctets.1 ifOutOctets.1 on [email protected]:::::1:v4only
at /usr/bin/mrtg line 2202
2014-04-10 08:55:59: WARNING: skipping because at least the query for ifInOctets.1 on 10.10.0.25 did not succeed
2014-04-10 08:55:59: WARNING: no data for ifInOctets&ifOutOctets:[email protected]. Skipping further queries for Host 10.10.0.25 in this round.
SNMP Error:
SNMPv1_Session (remote host: "10.10.0.27" [10.10.0.27].161)
community: "public"
request ID: 1681153799
timeout: 2s
retries: 5
backoff: 1)
2014-04-10 08:55:59: WARNING: skipping because at least the query for ifInOctets.1 on 10.10.0.27 did not succeed
2014-04-10 08:55:59: WARNING: no data for ifInOctets&ifOutOctets:[email protected]. Skipping further queries for Host 10.10.0.27 in this round.
SNMP Error:
SNMPv1_Session (remote host: "10.10.0.29" [10.10.0.29].161)
community: "public"
request ID: 505699892
timeout: 2s
retries: 5
backoff: 1)
2014-04-10 08:55:59: WARNING: skipping because at least the query for ifInOctets.1 on 10.10.0.29 did not succeed
2014-04-10 08:55:59: WARNING: no data for ifInOctets&ifOutOctets:[email protected]. Skipping further queries for Host 10.10.0.29 in this round.
SNMP Error:
SNMPv1_Session (remote host: "10.10.0.6" [10.10.0.6].161)
community: "public"
request ID: 833950218
timeout: 2s
retries: 5
backoff: 1)
2014-04-10 08:55:59: WARNING: skipping because at least the query for ifInOctets.1 on 10.10.0.6 did not succeed
2014-04-10 08:55:59: WARNING: no data for ifInOctets&ifOutOctets:[email protected]. Skipping further queries for Host 10.10.0.6 in this round.
SNMP Error:
SNMPv1_Session (remote host: "10.10.0.19" [10.10.0.19].161)
community: "public"
request ID: 1189842727
timeout: 2s
retries: 5
backoff: 1)
SNMPGET Problem for ifInOctets.805306369 ifOutOctets.805306369 on [email protected]:::::1:v4only
2014-04-10 08:55:59: WARNING: skipping because at least the query for ifInOctets.805306369 on 10.10.0.19 did not succeed
2014-04-10 08:55:59: WARNING: no data for ifInOctets&ifOutOctets:[email protected]. Skipping further queries for Host 10.10.0.19 in this round.
SNMP Error:
SNMPv1_Session (remote host: "10.10.0.20" [10.10.0.20].161)
community: "public"
request ID: 770968647
timeout: 2s
retries: 5
backoff: 1)
2014-04-10 08:55:59: WARNING: skipping because at least the query for ifInOctets.805306369 on 10.10.0.20 did not succeed
2014-04-10 08:55:59: WARNING: no data for ifInOctets&ifOutOctets:[email protected]. Skipping further queries for Host 10.10.0.20 in this round.
SNMP Error:
SNMPv1_Session (remote host: "10.10.0.21" [10.10.0.21].161)
community: "public"
request ID: 181741302
timeout: 2s
retries: 5
backoff: 1)
2014-04-10 08:55:59: WARNING: skipping because at least the query for ifInOctets.805306369 on 10.10.0.21 did not succeed
2014-04-10 08:55:59: WARNING: no data for ifInOctets&ifOutOctets:[email protected]. Skipping further queries for Host 10.10.0.21 in this round.
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_1][_IN_] ' $target->[33]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_1][_OUT_] ' $target->[33]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_2][_IN_] ' $target->[34]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_2][_OUT_] ' $target->[34]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_3][_IN_] ' $target->[35]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_3][_OUT_] ' $target->[35]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_4][_IN_] ' $target->[36]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_4][_OUT_] ' $target->[36]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_5][_IN_] ' $target->[37]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_5][_OUT_] ' $target->[37]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_6][_IN_] ' $target->[38]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_6][_OUT_] ' $target->[38]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_7][_IN_] ' $target->[39]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_7][_OUT_] ' $target->[39]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_8][_IN_] ' $target->[40]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_8][_OUT_] ' $target->[40]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_9][_IN_] ' $target->[41]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_9][_OUT_] ' $target->[41]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_10][_IN_] ' $target->[42]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_10][_OUT_] ' $target->[42]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_11][_IN_] ' $target->[43]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_11][_OUT_] ' $target->[43]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_12][_IN_] ' $target->[44]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_12][_OUT_] ' $target->[44]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_13][_IN_] ' $target->[45]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_13][_OUT_] ' $target->[45]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_14][_IN_] ' $target->[46]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_14][_OUT_] ' $target->[46]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_15][_IN_] ' $target->[47]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_15][_OUT_] ' $target->[47]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_16][_IN_] ' $target->[48]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_16][_OUT_] ' $target->[48]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_17][_IN_] ' $target->[49]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_17][_OUT_] ' $target->[49]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_18][_IN_] ' $target->[50]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_18][_OUT_] ' $target->[50]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_19][_IN_] ' $target->[51]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_19][_OUT_] ' $target->[51]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_20][_IN_] ' $target->[52]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_20][_OUT_] ' $target->[52]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_21][_IN_] ' $target->[53]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_21][_OUT_] ' $target->[53]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_22][_IN_] ' $target->[54]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_22][_OUT_] ' $target->[54]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_23][_IN_] ' $target->[55]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_23][_OUT_] ' $target->[55]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_24][_IN_] ' $target->[56]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_24][_OUT_] ' $target->[56]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_25][_IN_] ' $target->[57]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_25][_OUT_] ' $target->[57]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_26][_IN_] ' $target->[58]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_26][_OUT_] ' $target->[58]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_27][_IN_] ' $target->[59]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_27][_OUT_] ' $target->[59]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_28][_IN_] ' $target->[60]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_28][_OUT_] ' $target->[60]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_29][_IN_] ' $target->[61]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_29][_OUT_] ' $target->[61]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_30][_IN_] ' $target->[62]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.25_30][_OUT_] ' $target->[62]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_1][_IN_] ' $target->[63]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_1][_OUT_] ' $target->[63]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_2][_IN_] ' $target->[64]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_2][_OUT_] ' $target->[64]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_3][_IN_] ' $target->[65]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_3][_OUT_] ' $target->[65]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_4][_IN_] ' $target->[66]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_4][_OUT_] ' $target->[66]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_5][_IN_] ' $target->[67]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_5][_OUT_] ' $target->[67]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_6][_IN_] ' $target->[68]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_6][_OUT_] ' $target->[68]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_7][_IN_] ' $target->[69]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_7][_OUT_] ' $target->[69]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_8][_IN_] ' $target->[70]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_8][_OUT_] ' $target->[70]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_9][_IN_] ' $target->[71]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_9][_OUT_] ' $target->[71]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_10][_IN_] ' $target->[72]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_10][_OUT_] ' $target->[72]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_11][_IN_] ' $target->[73]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_11][_OUT_] ' $target->[73]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_12][_IN_] ' $target->[74]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_12][_OUT_] ' $target->[74]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_13][_IN_] ' $target->[75]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_13][_OUT_] ' $target->[75]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_14][_IN_] ' $target->[76]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_14][_OUT_] ' $target->[76]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_15][_IN_] ' $target->[77]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_15][_OUT_] ' $target->[77]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_16][_IN_] ' $target->[78]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_16][_OUT_] ' $target->[78]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_17][_IN_] ' $target->[79]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_17][_OUT_] ' $target->[79]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_18][_IN_] ' $target->[80]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_18][_OUT_] ' $target->[80]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_19][_IN_] ' $target->[81]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_19][_OUT_] ' $target->[81]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_20][_IN_] ' $target->[82]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_20][_OUT_] ' $target->[82]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_21][_IN_] ' $target->[83]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_21][_OUT_] ' $target->[83]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_22][_IN_] ' $target->[84]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_22][_OUT_] ' $target->[84]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_23][_IN_] ' $target->[85]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_23][_OUT_] ' $target->[85]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_24][_IN_] ' $target->[86]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_24][_OUT_] ' $target->[86]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_97][_IN_] ' $target->[87]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.27_97][_OUT_] ' $target->[87]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_1][_IN_] ' $target->[88]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_1][_OUT_] ' $target->[88]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_2][_IN_] ' $target->[89]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_2][_OUT_] ' $target->[89]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_3][_IN_] ' $target->[90]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_3][_OUT_] ' $target->[90]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_4][_IN_] ' $target->[91]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_4][_OUT_] ' $target->[91]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_5][_IN_] ' $target->[92]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_5][_OUT_] ' $target->[92]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_6][_IN_] ' $target->[93]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_6][_OUT_] ' $target->[93]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_7][_IN_] ' $target->[94]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_7][_OUT_] ' $target->[94]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_8][_IN_] ' $target->[95]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_8][_OUT_] ' $target->[95]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_9][_IN_] ' $target->[96]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_9][_OUT_] ' $target->[96]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_10][_IN_] ' $target->[97]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_10][_OUT_] ' $target->[97]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_11][_IN_] ' $target->[98]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_11][_OUT_] ' $target->[98]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_12][_IN_] ' $target->[99]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_12][_OUT_] ' $target->[99]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_13][_IN_] ' $target->[100]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_13][_OUT_] ' $target->[100]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_14][_IN_] ' $target->[101]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_14][_OUT_] ' $target->[101]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_15][_IN_] ' $target->[102]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_15][_OUT_] ' $target->[102]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_16][_IN_] ' $target->[103]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_16][_OUT_] ' $target->[103]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_17][_IN_] ' $target->[104]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_17][_OUT_] ' $target->[104]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_18][_IN_] ' $target->[105]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_18][_OUT_] ' $target->[105]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_19][_IN_] ' $target->[106]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_19][_OUT_] ' $target->[106]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_20][_IN_] ' $target->[107]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_20][_OUT_] ' $target->[107]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_21][_IN_] ' $target->[108]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_21][_OUT_] ' $target->[108]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_22][_IN_] ' $target->[109]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_22][_OUT_] ' $target->[109]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_23][_IN_] ' $target->[110]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_23][_OUT_] ' $target->[110]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_24][_IN_] ' $target->[111]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_24][_OUT_] ' $target->[111]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_174][_IN_] ' $target->[112]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.29_174][_OUT_] ' $target->[112]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_1][_IN_] ' $target->[119]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_1][_OUT_] ' $target->[119]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_2][_IN_] ' $target->[120]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_2][_OUT_] ' $target->[120]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_3][_IN_] ' $target->[121]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_3][_OUT_] ' $target->[121]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_4][_IN_] ' $target->[122]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_4][_OUT_] ' $target->[122]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_5][_IN_] ' $target->[123]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_5][_OUT_] ' $target->[123]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_6][_IN_] ' $target->[124]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_6][_OUT_] ' $target->[124]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_7][_IN_] ' $target->[125]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_7][_OUT_] ' $target->[125]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_8][_IN_] ' $target->[126]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_8][_OUT_] ' $target->[126]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_9][_IN_] ' $target->[127]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_9][_OUT_] ' $target->[127]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_10][_IN_] ' $target->[128]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_10][_OUT_] ' $target->[128]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_11][_IN_] ' $target->[129]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_11][_OUT_] ' $target->[129]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_12][_IN_] ' $target->[130]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_12][_OUT_] ' $target->[130]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_13][_IN_] ' $target->[131]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_13][_OUT_] ' $target->[131]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_14][_IN_] ' $target->[132]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_14][_OUT_] ' $target->[132]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_15][_IN_] ' $target->[133]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_15][_OUT_] ' $target->[133]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_16][_IN_] ' $target->[134]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_16][_OUT_] ' $target->[134]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_17][_IN_] ' $target->[135]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_17][_OUT_] ' $target->[135]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_18][_IN_] ' $target->[136]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_18][_OUT_] ' $target->[136]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_19][_IN_] ' $target->[137]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_19][_OUT_] ' $target->[137]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_20][_IN_] ' $target->[138]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_20][_OUT_] ' $target->[138]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_21][_IN_] ' $target->[139]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_21][_OUT_] ' $target->[139]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_22][_IN_] ' $target->[140]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_22][_OUT_] ' $target->[140]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_23][_IN_] ' $target->[141]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_23][_OUT_] ' $target->[141]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_24][_IN_] ' $target->[142]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_24][_OUT_] ' $target->[142]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_99][_IN_] ' $target->[143]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.6_99][_OUT_] ' $target->[143]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_805306369][_IN_] ' $target->[463]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_805306369][_OUT_] ' $target->[463]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_1073741824][_IN_] ' $target->[464]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_1073741824][_OUT_] ' $target->[464]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_1073741826][_IN_] ' $target->[465]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_1073741826][_OUT_] ' $target->[465]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_1073741827][_IN_] ' $target->[466]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_1073741827][_OUT_] ' $target->[466]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_1073741828][_IN_] ' $target->[467]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_1073741828][_OUT_] ' $target->[467]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_1073741832][_IN_] ' $target->[468]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_1073741832][_OUT_] ' $target->[468]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_1073741833][_IN_] ' $target->[469]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_1073741833][_OUT_] ' $target->[469]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_1073741835][_IN_] ' $target->[470]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_1073741835][_OUT_] ' $target->[470]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_1073741836][_IN_] ' $target->[471]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_1073741836][_OUT_] ' $target->[471]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_1073741837][_IN_] ' $target->[472]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_1073741837][_OUT_] ' $target->[472]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_1073741839][_IN_] ' $target->[473]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.19_1073741839][_OUT_] ' $target->[473]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.20_805306369][_IN_] ' $target->[474]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.20_805306369][_OUT_] ' $target->[474]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.20_1073741824][_IN_] ' $target->[475]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.20_1073741824][_OUT_] ' $target->[475]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.20_1073741825][_IN_] ' $target->[476]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.20_1073741825][_OUT_] ' $target->[476]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.20_1073741826][_IN_] ' $target->[477]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.20_1073741826][_OUT_] ' $target->[477]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.20_1073741827][_IN_] ' $target->[478]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.20_1073741827][_OUT_] ' $target->[478]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.20_1073741828][_IN_] ' $target->[479]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.20_1073741828][_OUT_] ' $target->[479]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.20_1073741829][_IN_] ' $target->[480]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.20_1073741829][_OUT_] ' $target->[480]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.20_1073741830][_IN_] ' $target->[481]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.20_1073741830][_OUT_] ' $target->[481]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.20_1073741832][_IN_] ' $target->[482]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.20_1073741832][_OUT_] ' $target->[482]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.21_805306369][_IN_] ' $target->[483]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.21_805306369][_OUT_] ' $target->[483]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.21_1073741824][_IN_] ' $target->[484]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.21_1073741824][_OUT_] ' $target->[484]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.21_1073741825][_IN_] ' $target->[485]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.21_1073741825][_OUT_] ' $target->[485]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.21_1073741826][_IN_] ' $target->[486]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.21_1073741826][_OUT_] ' $target->[486]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.21_1073741827][_IN_] ' $target->[487]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.21_1073741827][_OUT_] ' $target->[487]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.21_1073741828][_IN_] ' $target->[488]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.21_1073741828][_OUT_] ' $target->[488]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.21_1073741830][_IN_] ' $target->[489]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.21_1073741830][_OUT_] ' $target->[489]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.21_1073741832][_IN_] ' $target->[490]{$mode} ' did not eval into defined data
2014-04-10 08:57:14: ERROR: Target[10.10.0.21_1073741832][_OUT_] ' $target->[490]{$mode} ' did not eval into defined data
[root@nagios ~]# ll -d /etc/mrtg
drwxr-xr-x. 2 root root 4096 Apr 10 08:57 /etc/mrtg
[root@nagios ~]# ll /etc/mrtg
total 1108
-rw-r--r--. 1 apache nagios 1130455 May 31 2013 mrtg.cfg
-rw-r--r-- 1 root root 0 Apr 10 08:57 mrtg.ok
You have some errors in the mrtg configuration. You will need to fix this. Normally, running the following command:
should not produce any output (if everything is OK).
How many ports do you have on this particular switch?
Run the following command and show the output:
Have you tried re-adding the switch by following the steps, outlined in this document?
LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfgHow many ports do you have on this particular switch?
grep ":::::2" /etc/mrtg/mrtg.cfg | head -n 5Be sure to check out our Knowledgebase for helpful articles and solutions!
Its a 48port cisco stack.[root@nagios ~]# grep ":::::2" /etc/mrtg/mrtg.cfg | head -n 5
# /usr/bin/cfgmaker --show-op-down --zero-speed=100000000 --snmp-options=:::::2 --noreversedns [email protected]
# Target[10.5.1.2_1]: 1:[email protected]:::::2
Target[10.5.1.2_2]: 2:[email protected]:::::2
Target[10.5.1.2_3]: 3:[email protected]:::::2
# Target[10.5.1.2_4]: 4:[email protected]:::::2
I tried the document. having difficulty finding the item in the cfg. Also there are ones in there that i know Ive deleted from nagios
When you remove them from Nagios they will still remain in the mrtg.cfg file, unfortunately this is how MRTG works. I know that there had been talk about harnessing something to auto-remove the mrtg.cfg definitions after removing them from nagios but currently it has to be done by hand.
