returning special characters using nrpe
[email protected]
Post by [email protected] »
How do I keep the special characters returned by the plugin ?
The (>) symbol is being stripped out ?
I see the alert with the (>)
[1397151893] SERVICE ALERT: SV724;check_emp;WARNING;HARD;2;WARNING (35) > 10
But the Notification does not have the (>), it seems to be stripped out.
[1397151893] SERVICE NOTIFICATION: NAG01;SV724;check_emp;WARNING;notify-service-Master;WARNING (35) 10
Thanks for any advice
sreinhardt
-fno-stack-protector
Re: returning special characters using nrpe
Post by sreinhardt »
That is actually considered a nasty metacharacter. If you wish to allow it, you will need to download the tar or git clone the nrpe code, and remove that character from src/nrpe.c on line 56, then recompile. This may need to be done for both send_nrpe and the server, or just the server. I would give it a shot on just the server receiving the response and if that does not work, also rebuild the plugin.
[email protected]
Thanks, I think I try harder to leave it out.
sreinhardt
You're welcome, I can see where that is a nice way to display it, but it can cause some issues with nrpe and hence the exclusion of it.
