Unable to delete from Service Status Detail screen
dbsaust
Post by dbsaust »
Hi, since rolling out Nagios XI 2011R1.5 (using your R1.4 Virtual build and then adding the latest 1.5 update) I am unable to remove services and hosts via the XI frontend, i.e the Service/Host Status Detail screen >> Configure tab >>Delete this service/host.
I do not receive any errors at this point and it all appears to have worked, but the item does not get removed.
This not urgent issue as i can remove the items from the Core Config manger with no issue, but would like to regain the functionality via the front end.
Is this a simple permissions issue somewhere?
I have attached the latest config snapshot if this is needed for this type of issue? If you need anything else please let me know.
Thanks in advance.
Kind Regards
Dan Carpenter
nscott
Re: Unable to delete from Service Status Detail screen
Post by nscott »
Dan,
Thanks for bringing this to our attention. I'll try and duplicate your issue and see what I can find out.
Nicholas Scott
mguthrie
Post by mguthrie »
Bug confirmed and fixed! Thanks for the heads up. The fix will be present in the next release. If you need a patched script before then let me know and I'll post it.
