Hi all ,
i have problems when i use manually added plugins from exchange.nagios.org website , i get this error in the information status colomn of nagios web inetrface :
(No output on stdout) stderr: execvp(/usr/local/nagios/libexec/check_cpu, ...) failed. errno is 2: No such file or directory
although it works in the client side "solaris 10" . and when i use plugins installed by default " plugins v 2.15 " they work very well . any help please , i use nagios core 4.0.1 over Centos 6.5
plugins problem
Re: plugins problem
Okay so it looks like this is actually occurring when you run NRPE checks to that server? Or are you using check_by_ssh? What are the permissions on that plugin on the remote host?:
ls -la /usr/local/nagios/libexec/check_cpu-
mohd khalid
Re: plugins problem
Thanks i fixed it by just defining commands after nrpe like this :
command_line /$USER1/check_nrpe -H $HOSTADDRESS$ -c $myplugin
