Hi all
I want to make service dependency that all the depended host will remind on they last stat (OK) and the only alert will be on the main service.
I's for NRPE service that will run first and if he are down all the rest of the NRPE services remain on OK stat.
also want to check if 8.8.8.8 are answering and if not all the hosts will be without change
Service dependency remind on "last state"
sreinhardt
- -fno-stack-protector
Re: Service dependency remind on "last state"
It sounds like you really need to look into nagios bpi, for extended cases that core doesn't really handle. http://exchange.nagios.org/directory/Ad ... I)/details Take a look and see if that might suite your needs.
