Unable to connect to PostgreSQL server: FATAL: Ident authen
vsara90
Post by vsara90 »
Hi All,
Currently, we are facing issue with Nagios XI.
i.e., in UI, we couldn't able to login and getting the following error.
"DB Connect Error [nagiosxi]: Database connection failed"
By checking the httpd log, we identified the following issue with postgres.
"psql: FATAL: Ident authentication failed for user "nagiosxi""
Also, we changed the pg_hba.conf and changed the IDENT to TRUST.
But it didn't work.
Please help
Thanks.
abrist
Red Shirt
Re: Unable to connect to PostgreSQL server: FATAL: Ident au
Post by abrist »
Have you changed any of the database passwords?
Can you log into the postgresql db locally?
echo "\dt" | psql nagiosxi nagiosxi
