Deactivating service nrpe
quental
Post by quental »
Good morning
In my remote machine the following error in /var/log/messages
Deactivating service nrpe due to excessive incoming connections. Restarting in 10 seconds.
This results in the console NagiosXI:
Check_nrpe: Error - Could not complete SSL handshake.
How I can solve this problem without changing my time monitoring?
Thanks for your time.
regards
quental
Re: Deactivating service nrpe
Post by quental »
My xinetd.conf:
cps = 50 10
instances = UNLIMITED
per_source = UNLIMITED
Regards
You will likely need to remove the cps parameter from xinetd configuration
from http://linux.die.net/man/5/xinetd.conf :
cps
Limits the rate of incoming connections. Takes two arguments. The first argument is the number of connections per second to handle. If the rate of incoming connections is higher than this, the service will be temporarily disabled. The second argument is the number of seconds to wait before re-enabling the service after it has been disabled. The default for this setting is 50 incoming connections and the interval is 10 seconds.
quental
Post by quental »
Thank you very much Scott
I have 83 monitoring at moment.
I changed the value in my linux for the cps.
Regards
Post by slansing »
Are you saying that this is resolved now? If so I will close the thread.
