Is there method of using a script to add a host to a nagiosXI server somehow. We bring VM's up and down for temporary uses that need to be monitored. The VM's are scripted and I would like to write a script for automating the addition of these servers to Nagios.
Regards,
Randy.
Nagios XI 2012R2.9
Redhat 6.5
Script to add machines to nagios
sreinhardt
- -fno-stack-protector
Re: Script to add machines to nagios
I would highly suggest taking a look at the talk below from Activision at our world conference in 2012.
http://vimeo.com/52112155
http://exchange.nagios.org/directory/Mu ... te/details
See if that will suite your needs, I think its a pretty close although probably not perfect fit.
intelXIadmin
Where to find documentation?
Thank you for the reply on this. It may be a solution for us. Where can I find some documentation on this?
Regards,
Randy.
Regards,
Randy.
Well, the documentation is found in the form of slides for the most part . . .
intelXIadmin
About all the slides say is the Auto Deployment feature is available in 2011R3.2, unless I am missing something. Where is this feature at on the server?abrist wrote:Well, the documentation is found in the form of slides for the most part . . .
Regards,
Randy.
Hey intelXIadmin,
I believe what you are looking for is this:
http://assets.nagios.com/downloads/nagi ... gement.pdf
That should show you how to automate the processes that were talked about in those slides.
