Date-Time for a timezone
I updated the php.ini to be East Coast time in support of the "Last Updated" note under each dashlet. What I'm now curious about is the actual data. Would the x-axis also be in EST?
Re: Date-Time for a timezone
It should be EST as well. The right-most side of the graph is the current time, and the x-axis labels are very 6 hours, so you can eyeball it and see if the current time is an appropriate distance from the last label.
I took this pic at 15:00 EST and it shows 21:00 at the right most point. That confused me.
Is your system time synced up with your PHP time?
Please run the following:
grep "date.timezone" /etc/php.ini
php -r 'echo date("D M j G:i:s T Y")."\n";'
date
My 12-hour math was wrong earlier, it was 2 p.m. PST which is 5 p.m. EST/17:00 EST.
It looks like it's not. Should i fix the system time and that will fix the graph times?
[root@Nagios1 ~]# grep "date.timezone" /etc/php.ini
; http://www.php.net/manual/en/datetime.c ... e.timezone
date.timezone = America/New_York
[root@Nagios1 ~]# php -r 'echo date("D M j G:i:s T Y")."\n";'
Wed Apr 16 17:16:29 EDT 2014
[root@Nagios1 ~]# date
Wed Apr 16 21:16:33 UTC 2014
[root@Nagios1 ~]#
[root@Nagios1 ~]#
The following should fix you up:
assuming that New York is the proper system time you would want. As long as PHP matches the system you are fine.
rm /etc/localtime
cp /usr/share/zoneinfo/America/New_York /etc/localtime
good to go! thank you!
yes, our data center is on the east coast so all times EST.
Great. It will take a bit for everything to sync up and you may see some issues until then.Sbergonzi wrote:good to go! thank you!
I'll be closing this thread now, but feel free to open another if you need anything in the future!
