Upgrade Nagios Plugins on XI
Is there any way in the XI webinterface to upgrade the nagios plugins on Nagios XI ?
Re: Upgrade Nagios Plugins on XI
Not through the web interface, you would need to re-compile them from source, with new XI versions, one the plugins packages are tested thoroughly, they will be released by us.
To that end, I would not recommend manually updating them, if something changed in a plugin and a, say, wizard, required it to be there in it's current state then it could break.
Nagios plugins were automatically upgraded during upgrade to 2014R1.1
http://assets.nagios.com/downloads/nagi ... S-2014.TXT
