Dear Team,
We are monitoring Oracle using oraclehealth plugin. some trace files are being generated in the server and increasing the utilization. please suggest deleting of those trace files will affect the system or not. so that we can remove the same.
have attached one single trace file for your reference.
regards,
Trace Files
wiproltdwiv
Trace Files
Re: Trace Files
This is automated oracle debugging stuff, I suggest you talk to your DBA about that.
https://community.oracle.com/thread/2297940?tstart=0
