I'm new here so I hope this is the place to show how we modified Nagios to reflect the current status in the title bar, so for tabbed browsers you can simply glance and the tab is see if everything is OK.
Edit cgi/status.c to add "nowrap" to host column (line 1671). /* because I don't like it when hostnames wrap */
Before the main() code add a global variable:
int title_problems = 0;Code: Select all
title_problems += total_problems;Code: Select all
if(title_problems == 0)
printf("<script> top.document.title='OK - Freedom Communications Nagios';</script>\n");
else
printf("<script> top.document.title='PROBLEMS - Freedom Communications Nagios';</script>\n");
if((total_hosts == hosts_up) && (total_services == services_ok))
else
Bob.
