I want to access Nagios Core web interface without providing user name and password. This option should not allow the logged in user to edit any config file, but he should be able to view the services, hosts and host groups. Only authenticated users should be allowed to edit any config. Could you please elaborate on the procedure to achieve this.
Dipu
Access Nagios Core without authentication
Re: Access Nagios Core without authentication
Turning off all security is never a good idea! We don't recommend that you do this, but since you asked - here you go:
To turn off all authentication:
Change the following line in the "/usr/local/nagios/etc/cgi.cfg" from:
to
Modify the "/etc/httpd/conf.d/nagios.conf" file, so it is going to look like this:
Restart apache and nagios:
To set up read-only users:
In the cgi.cfg file, set up a "read-only" user (e.i. john):
To set up a user with a full access to hosts/services (like the nagiosadmin)
use_authentication=1Code: Select all
use_authentication=0Code: Select all
# SSLRequireSSL
Options ExecCGI
AllowOverride None
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
# Allow from 127.0.0.1
# AuthName "Nagios Access"
# AuthType Basic
# AuthUserFile /usr/local/nagios/etc/htpasswd.users
# Require valid-user
</Directory>
Alias /nagios "/usr/local/nagios/share"
<Directory "/usr/local/nagios/share">
# SSLRequireSSL
Options None
AllowOverride None
Order allow,deny
Allow from all
# Order deny,allow
# Deny from all
# AuthType Basic
</Directory>Code: Select all
service httpd restart
service nagios restartIn the cgi.cfg file, set up a "read-only" user (e.i. john):
authorized_for_all_services=nagiosadmin,john
authorized_for_all_hosts=nagiosadmin,john
authorized_for_read_only=johnCode: Select all
authorized_for_system_information=nagiosadmin,john
authorized_for_configuration_information=nagiosadm,john
authorized_for_system_commands=nagiosadmin,john
authorized_for_all_service_commands=nagiosadmin,john
authorized_for_all_host_commands=nagiosadmin,johnCode: Select all
service nagios restartBe sure to check out our Knowledgebase for helpful articles and solutions!
ozeryumsek
Hello
I did the configuration changes but it still asks for username/password.
Im trying to monitor nagios on samsung smart tv. Browser on the smart tv doesnt show password screen so I need to disable security and authentication parameters.
Please help about this issue.
Regards.
Regards.
Having unsecured nagios server out in the open is a horrible idea. The described mods in my previous post should work. You would need to forward a port and use the external IP to access the nagios server on your Samsung smart TV.
