wrong URL link in password reset link
kendallchenoweth
Post by kendallchenoweth »
I backed up my development Nagios XI environment and used the backup file to build up my QA environment (and then made appropriate edits to distinguish it). There is still one minor problem. The password reset link on my QA environment uses the development system URL. I can't find where in the nagiosxi directory to correct this.
It's not time sensitive, but I would like to correct this and, more importantly, understand if I can, in the future, use a restore a backup from one server on another server without unintended side effects.
Thanks!
abrist
Red Shirt
Re: wrong URL link in password reset link
Post by abrist »
The URL is set in the UI: Admin --> Manage System Config. You can also reset the nagios admin password by following this faq entry: http://support.nagios.com/wiki/index.ph ... n_Password
