How do I check nagios core Database ?
Because I dont see nagios database when I run
SHOW DATABASES;
What is default nagios core database is it Mysql / Posgresql ?
Nagios Core Database
Re: Nagios Core Database
Nagios Core does not use a database; all config settings are stored on-disk in flat files.
lafargeuser
Thanks. As I was not aware of that.
But is there any possibilities I can see those config settings which stored on-disk in flat files.
Yes you can, it is shown in almost every document that requires you to edit nagios configs, take a look at this page...:
http://nagios.sourceforge.net/docs/3_0/toc.html
If you have set up any hosts, services, groups, contacts, etc, you would have been editing those files...
